Vegas Pro 12 – Preview Lag
Posted by Scott Gibson on January 9, 2014 at 11:36 pmI know that this question is asked too often as it is a common issue within Sony Vegas, but it is really bugging me now. I have a good desktop primarily for HD video editing. Here are my specs:
– Intel i7 3770k @3.40GHZ
– 16GB DDR3 Ram
– Nvidia GeForce 560ti (1GB)
– 2TB 7200rpm hard drive
I have been working on Vegas for a number of years now and I have just about had it with the preview lag which completely slows down my workflow. I have begun editing with Cineform in an .avi container to see if it would make a difference – it did help slightly, there was less lag. Does the issue lie with my graphics card – it’s not top of the range? Or is it something else? As soon as I even add a fade or any other effects to clips the preview begins to constantly skip frames. It would be great to hear your thoughts. PS: I usually work with 1080p footage. Cheers.Stephen Crye replied 12 years, 7 months ago 5 Members · 13 Replies -
Graham Bernard
January 10, 2014 at 4:25 amYou list one hard drive. Is your media on that same drive?
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Steve Rhoden
January 10, 2014 at 7:22 amThat’s how Vegas is Scott, once you add multiple effects/filters
you are gonna experience playback lag. What you can use is the
Dynamic Ram Preview feature.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Scott Gibson
January 10, 2014 at 9:06 amHi Graham, thanks for your reply. Yes, I have all of my programs installed on this drive along with my media. Would it be a better option to invest in an SSD primarily for the programs and use the 2TB drive just for the media? Thanks
Scott Gibson
January 10, 2014 at 9:18 amHi Steve, you are right with this but I am literally adding one effect to a clip and the framerate drops completely. I started working with the NewBlue Titler Pro plugin and the preview window is literally showing freeze-frames – 1 every few seconds, which makes editing very hard. I’m constantly having to pre-render parts of the timeline to see an edit which completely slows down my workflow. Is my PC at a high enough spec? Or is this a Vegas problem? Cheers
Scott
Scott Gibson
January 10, 2014 at 9:19 amHi Graham, thanks for your reply. Yes, I have all of my programs installed on this drive along with my media. Would it be a better option to invest in an SSD primarily for he programs an use the 2TB drive just for the media? Thanks
Roger Bansemer
January 10, 2014 at 11:11 amIf you’re using a GoPro, the mp4 files it produces will gag with vegas11.
Also, do you have your preview set for “auto”?Roger Bansemer – PaintingAndTravel.com
Scott Gibson
January 10, 2014 at 6:13 pmHi Roger, No it depends on what project I’m working on – sometimes it’s Canon 600d (T3i) footage and other times it’s footage that’s already been provided in various formats, but I haven’t worked with GoPro footage before but instead use their Cineform codec to transcode other media to .avi. I’m working on Pro 12 at the moment and I’m virtually always on preview (auto) or even draft for some projects still with consistent preview lag! Have you had similar issues? Cheers
Scott
Stephen Crye
January 13, 2014 at 6:10 amExperiment with lower quality/size in the Preview window, and also do not use “auto” for the window size. That eats up CPU. I know it is frustrating to not see sharp detail in the preview window; when you need that do a bit of Dynamic RAM preview
Run Process Explorer to see where your bottleneck is – CPU or GPU.
Good luck,
Steve
Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
Stephen Crye
January 13, 2014 at 6:20 amMultiple drives are essential.
I use external drive bays (such as Nexstar) for SATA drives that hold the source media, and an internal Seagate SSD/platter Hybrid drive for Vegas temp files (set this location in Vegas). This way, Vegas is never writing different files to the same drive at the same time.
Try an SSD for your OS and the drive where Vegas runs. Buy something like a Corsair Neutron GTX for Windows. That will free up your 2 TB drive for the temp files.
These little babies are lifesavers – let you buy cheap bare SATA drives and swap them at will:
https://www.vantecusa.com/en/product/view_detail/495Even with all this, renders are still very CPU-bound.
Steve
Graham Bernard
January 13, 2014 at 7:13 amBack in the Day (!) I used to edit on a DELL Schlaptop. Sure, it has a fair-sized drive, but as soon as I liberated its single System drive by adding 3 additional drives via something like this PCMCIA Multiple F/W adaptor. I was able to run external drives AWAY from my system drive, Vegas just flew! But then I got my first Tower PC with 5 internal drives . . . . I’m now on my 2nd Tower PC and Vegas is like running Microsoft WORD – mostly!.
Cheers
Grazie
