Activity Forums VEGAS Pro Vegas Pro 12, graphic in credits crawl
  • Vegas Pro 12, graphic in credits crawl
    Posted by Michael Gibrall on September 9, 2013 at 2:18 pm
    Hello all.
    I’ve added a graphic I’m required to place in my credit crawl at the end of a film.
    I created a video track above the credit crawl and timed out the graphic’s motion to match that of the crawl.
    However, there is some kind of default crop border where the graphic disappears before the graphic reaches the top of the screen.
    How do I eliminate this (as well as the bottom)
    Thanks in advance.
    John Rofrano replied 12 years, 12 months ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    September 9, 2013 at 2:46 pm
    Simply center the graphic (Dont crop it) and just use the track motion
    to resize and keyframe it to the position and pace to the rest of the
    crawl.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • John Rofrano
    September 9, 2013 at 3:16 pm
    [Michael Gibrall] “How do I eliminate this (as well as the bottom)”
    Open Pan/Crop on the graphic event and right-click the window and select Match Output Aspect. This will make the graphic aspect the same as the project and it shouldn’t get cut off anymore.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Michael Gibrall
    September 9, 2013 at 5:59 pm
    I’m afraid when I select match output ratio the logo slightly flies forward as it scrolls up, then back, and there is still cutoff on the top and bottom.
  • Steve Rhoden
    September 9, 2013 at 6:32 pm
    Thats because maybe you have the Sync Cursor enabled and it created
    an additional keyframe… Delete the extra keyframe.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Michael Gibrall
    September 10, 2013 at 4:21 am
    Thank you both. Between your messages, I got it to work.
  • Steve Rhoden
    September 10, 2013 at 9:54 am
    ok, good!
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • John Rofrano
    September 10, 2013 at 10:30 am
    Yea, you have to watch that you don’t create keyframes that you didn’t intend to. When opening Pan/Crop always make sure that you have the first keyframe highlighted. Glad you figured it out.
    ~jr
