Vegas Pro 10.0c just released
Posted by Tom Pauncz on January 4, 2011 at 7:56 pmSubject says it all. :0)
Cheers for now,
Tom Pauncz
(30WEST MEDiA GROUP)Kate Morris replied 15 years, 8 months ago 5 Members · 4 Replies -
Mike Kujbida
January 4, 2011 at 7:57 pmNotable fixes/changes in Version 10.0c
* Fixed problems that could occur when rendering to Sony AVC format.
Steve Rhoden
January 5, 2011 at 1:33 amUpdates are quick and true solutions…A company that really listens
to its customers.Steve Rhoden
(Cow Leader)
Creative Arts Director and Film Maker.
Project Samples at:
http://www.youtube.com/hentys -
Al Bergstein
January 5, 2011 at 5:11 amLet’s bring any newbies up to the present…here’s the 10.x upgrade issues…this is GOOD news not a slam. I like a company that publishes what it fixes. This shows me that there are active Program Managers that are logging bugs, and developers who are prioritizing and fixing them. There are ALWAYS bugs in software, and always will be, a developer and test team CANNOT test every possible sceneario, so upgrading is preferable to not as long as you know the issues you face (ie. do you have enough RAM, etc.) Not all users will experience ALL of these problems. Some are unique to specific hardware situations, or things like AVCHD. I don’t work for or have any interest in Sony, but have worked for a major software company in the past, and know how the sausage gets made. It’s ugly folks…(G)
Notable fixes/changes in Version 10.0b
Added the ability to configure encoded format, interlace mode, and quality of CineForm™ encoding.
Added 24p Blu-ray Disc rendering templates.
Decreased startup time when many OFX plug-ins are installed.
Fixed a crash that could occur when opening a project using a missing OFX generator.
Fixed a crash that could occur when using Save Media with Project with media that had stabilization applied.
Fixed a crash that could occur when replacing media with stabilization applied.
Fixed a crash that could occur when starting playback after reordering audio track effects multiple times.
Fixed a crash that could occur when loading a project using media generators if the Video Media Generators window was open.
Fixed some issues in AC-3 Pro rendering format (muted LFE channel when using the “2/0 (L, R) + LFE” template, enabled LFE option for “1/0 (C)” and “2/0 (L,R)” templates, don’t show “2/0 (L, R) + LFE” template for stereo projects).
Fixed an issue smart rendering to MPEG-2 standard definition.
Fixed an issue that could cause video track effects to be processed as pre-composite after dragging the plug-in to the post-composite position in the Video Track FX window.
Fixed an issue adding 5.1 surround plug-ins to the master bus in a 5.1 surround project.
Fixed an issue that could prevent FX Bus input meters from functioning.
Fixed an issue that could prevent FX from being heard in the Apply Non-Real-Time Event FX dialog.
Fixed time, tempo, and meter information passed to VST plug-ins.
Fixed a hang that could occur when using 32-bit VST plug-ins in the 64-bit version of Vegas Pro.
Fixed audio glitches that could occur when scrubbing in a 5.1 surround project.
Fixed an issue with OFX presets for fractional values when saved or loaded with certain language settings active.
Fixed an issue loading large presets for OFX plug-ins.
Fixed an issue with OFX plug-ins that vary output even with fixed parameters.
Fixed an issue that could cause OFX temporal frame access to be incorrect when rendering to a file.
Fixed an issue loading and saving OFX presets that contain large amounts of data.
Fixed an issue that could cause keyframes for OFX plug-ins to move to the start of the FX timeline.
Fixed an issue that could cause an Undo operation in the video FX timeline to move all keyframes to the start of the FX timeline.
Fixed incorrect results with certain OFX transition effect plug-ins when used on still images.
Fixed OFX keyframe interpolation for certain cases.
Fixed an issue that could cause the Stereoscopic 3D Adjust plug-in to create interlace patterns in the image.
Fixed an issue that could prevent the Auto Correct function in Stereoscopic 3D Adjust from working properly with source images requiring flips.
Fixed an issue that could cause removal of stabilization to could change the range of time represented by a subclip.
Fixed a crash that could occur when a string consisting entirely of unsupported characters was entered for a closed caption.
Fixed an issue reading HDV clips captured with certain third-party tools.
Fixed a hang that could occur when compositing or crossfading between large still image sequences.
Fixed alpha channel for PNG images rendered as an image sequence.
Fixed a problem rendering projects using 32-bit floating point video as image sequences.
Expanded scripting properties and methods for stereoscopic 3D and OFX plug-ins. Scripting changes have been posted to the Vegas scripting forum.
Notable fixes/changes in Version 10.0a
Implemented numerous fixes in the video FX timeline editor.
Implemented numerous fixes in the OFX plug-in API.
Enabled 1080-50p/60p for Sony AVC.
Enabled B-frame rendering for nonbaseline profiles for Sony AVC.
Improved the MPEG-2 reader.
Fixed a crash when canceling two-pass MPEG-2 renders.
Fixed an issue that could cause FX automation envelopes to change which parameter they controlled when switching plug-ins using the Insert FX region of the Mixing Console.
Fixed an issue that could cause the wrong plug-in to be added when adding an effect from the Insert FX region of the Mixing Console.
Fixed an undo buffer error that could occur after bypassing FX on an Input Bus.
Fixed a crash when rendering a file when MIDI ports are enabled.
Fixed a reversal of the vertical offset direction in the Stereoscopic 3D Adjust plug-in if rotation and keystone adjustments were both zero.
Fixed missing render templates in the Export Video to XDCAM Disc dialog.
Fixed a crash when using Show Video Monitor in the Trimmer when stereoscopic 3D is active on the external monitor from the Video Preview window.
Fixed issues with Build Dynamic RAM Preview not stopping when requested if Pan/Crop window is open, or stopping early if Video FX window is open.Alf
Kate Morris
January 5, 2011 at 7:29 pmLet’s bring any newbies up to the present…here’s the 10.x upgrade issues…this is GOOD news not a slam. I like a company that publishes what it fixes.
I’ve been told on these forums that smart rendering to MPEG-2 standard definition is basically impossible …. since Vegas won’t let you render MPEG-2 SD without resampling the whole file.
What exactly did they fix – switching off the functionality completely?! 🙂
