Activity Forums VEGAS Pro Vegas Pro 10 trial install issue
  • Vegas Pro 10 trial install issue
    Posted by Paul Stacy on November 26, 2010 at 8:41 pm
    I’ve used Vegas for some time now. Converted from Premiere to Vegas 6, upgraded to Vegas 8 and am now considering moving to Vegas 10. My problem is that, after I download the trial, I get an error that says “Failed to extract dat file” when I try to open the .exe.
    The odd thing is that this is happening on THREE different machines and two different OS’s (1 Vista and 2 XP SP3s). What gives?
    Anyone have a similiar issue or have a suggestion? I can see something like this happening on one machine, but three? I’ve looked everywhere for a solution but cannot find anyting.
    Thanks for any help you can provide!
    Paul Stacy replied 15 years, 10 months ago 3 Members · 5 Replies
  • Frederic Baumann
    November 26, 2010 at 10:04 pm
    Looks strange…
    Have you checked that the size of the EXE file corresponds to the one mentioned on the Sony web site?
    You might try to re-download — just in case there has been a download error and the EXE file is corrupted?
    Hope this helps, good luck!
    Frédéric
    Looking for a white balance plug-in? Visit my web site.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my video tutorial:
    https://library.creativecow.net/baumann_frederic/Sony-Vegas_event-pan-crop-tool/1
    Or about Keyframes? https://library.creativecow.net/articles/baumann_frederic/Animating-with-Keyframes-in-Sony-Vegas.php
    French version: https://geo.creativecow.net/fr/a/12999
  • Paul Stacy
    November 27, 2010 at 12:29 am
    Thanks. Yes, I have tried re-downloading. And, since I have downloaded several times to different machines and a couple different OS’s, I’m stumped. Just seems odd that all three machines would possess the same configuration issues. Seems the common denominator is Vegas but, then again, haven’t heard of anyone else with this issue.
    Puzzled.
  • Frederic Baumann
    November 27, 2010 at 8:05 am
    Maybe it’s a bit overkill, but I have no better suggestion right now:
    – create a VMware virtual machine with a fresh Windows installation on it, and nothing else
    – try to install your Vegas setup on it, and see if it works
    – if it still does not work, I would definitely suspect the EXE file you have downloaded. I could successfully install Vegas Pro 10 32 and 64 on a Windows 7/64 VMware, and Vegas Pro 10 32 on a Windows XP 32 SP3 VMware, so I know it works.
    – if it works, then you might compare your Windows settings to the ones in the VMware. Easier to say than to do…
    I remember I had an issue installing Studio Platinum 10 on a XP 32 machine, and this was due to the version of the Windows Installer. Never figured out how to fix that. Maybe you could have a look into that way??
    Also, a stupid question: are you sure you have enough disk space for the setup to extract the DAT file successfully?
    Hope this helps,
    Frédéric
  • Al Bergstein
    November 28, 2010 at 8:32 am
    Ok. I’m going to venture a wild ass guess. Could it be that you downloaded the 64 bit version of Vegas and are trying to install it on a 32 bit system? Since we have such limited knowledge of your setups, this is the only thing that makes sense. As you mention, many of us have successfully downloaded Vegas 10 on many different types of machines. I am guessing that the 64 bit version might not even install on a 32 bit machine. Other than that, I’m out of ideas.
    Alf
  • Paul Stacy
    November 28, 2010 at 2:59 pm
    It’s definitely the the right version. 32 bit to 32 bit.
    I’ll figure it out eventually, I suppose. I’m thinking there must be a configuration issue somewhere and, as suggested earlier, I’ll just have to do some comparisons to find out what the differences are.
    Thanks for all the advice. And, of course, I’ll happily take any more that people what to give.
