Vegas Pro 10 – Composite Envelope Not affecting layer?
Hey guys, I’m looking for some help with Composite Envelopes.
What I’m trying to do:
I have an Adjustments Track containing simple Levels & S-Curve FX adjustment, which I am Applying successfully (source alpha mode?) to the Main Track – this all works perfectly.However, I would like to control how much & when this is applied, using a Composite Envelope and adding points (See image below). I know I can use keyframes and tweak, but this has proved too time consuming.
My problem is, that the Composite Envelope is NOT having any affect on the track below. Which is odd, because when I try a Mute Envelope, it DOES mute the FX correctly.
Am I missing something – is there a better(correct) way of doing this?
It’s like a steering wheel in my pants, driving me’ nuts!
