Activity Forums VEGAS Pro vegas pro 1 GPU Acceleration settings
  • vegas pro 1 GPU Acceleration settings
    Posted by Daniel Bane on April 5, 2022 at 3:06 pm
    I’m using Vegas pro 19. I have a question on GPU Acceleration settings.
    Everything I read told me to do the following to implement GPU acceleration in Vegas Pro 19
    1. Go to Options – Preference – Video and make sure to set dynamic ram to 0 and select your Video Card. No problem – done. (see screenshot below, labeled #1)
    2. The next setting to set was under File I/0. Two changes, but neither selection is available.
    I’m supposed to select “Enable hardware decoder for supported format, and below that select my video card from the drop-down menu for Hardware Decoder to Use.
    Obviously, if I don’t have ‘Enable hardware decoder for supported format” my video card is not going to be listed under the dropdown for Hardware Decoder to use. (see screenshot labeled #2)
    My Graphic card is NVIDIA GeForce GTX 1060 6GB. I contacted Nvidia tech support. No response.
    What am I doing wrong and is there a solution?
    John Bolton replied 4 years, 5 months ago 2 Members · 1 Reply
  • John Bolton
    April 14, 2022 at 7:39 am
    Have you got the latest Studio (not gaming) drivers installed?
    Click the HELP Tab and then select ( Check driver Updates )
    It is important that it is the STUDIO version
    Regards
