Activity Forums VEGAS Pro Vegas Preview Not Matching Render
  • Vegas Preview Not Matching Render
    Posted by Bob Wills on February 26, 2019 at 9:05 pm
    So I’m trying to render a series of videos for Youtube using 1920×1080 29.97 HEVC Nvidia Codec. And in my video preview my fade outs are smooth and perfect but when I go to render the video, the fade seems to hang and isn’t nearly as quick and smooth as it’s supposed to be. The project details match the render preview but I for the life me cannot figure out why this is happening.
    Francois Pénzes replied 7 years, 5 months ago 3 Members · 10 Replies
  • 10 Replies
  • George Dean
    February 26, 2019 at 9:16 pm
    Hi Bob, until we can put our finger on the exact cause, could you do a bit of process of elimination? I would turn OFF GPU acceleration of video process ( Preferences > Video tab). Also set the maximum number of rendering threads to ‘1’. Then render using the Magix AVC Mainconcept format. If that cures the issue, we then know (I think we know!) it is probably something with your GPU.
    More information may also help user here help…..OS system, Vegas version and build, Mediainfo (text mode) display of your source media specs. And of course (even though they are set the same) a screenshot of your Project settings and Render format template.
    Best Regards……George
  • Bob Wills
    February 26, 2019 at 9:50 pm
    Thanks for replying. I’m running Windows 7 with a GTX 1080 and an i7 4790k. Vegas 16 Build 361. After I turned off GPU Acceleration I am noticing that it seems to have fixed some of the issue. The fade out isn’t nearly as dark as it was and instead seems brighter. Not entirely sure why that is.
    What’s the difference between using GPU Acceleration and choosing the Nvidia Codec? Also what would be the significance of using only 1 thread? I’d like to get a solid understanding of what each of these do so I can figure out the best set up for me.
  • George Dean
    February 26, 2019 at 10:00 pm
    The setting I suggest you try are for testing to see if your GPU has any thing to do with you issue, not necessarily what you would choose as the best setup. These are things the community has used in the paste to run down an issue.
    Did those setting make any difference in the end result, the render?
  • George Dean
    February 26, 2019 at 10:06 pm
    Bob, does your Vegas show an option for the Intel HD Graphics in Preferences > Video
  • Bob Wills
    February 26, 2019 at 10:45 pm
    No I don’t see that in there. There is an improvement with GPU Acceleration off. I wouldn’t say it entirely fixed the problem but it is an improvement. Like I said I think GPU Accel is making the video darker which in turn means the fade is darker so it makes it appear as though its a slower transition.
  • Bob Wills
    February 26, 2019 at 10:54 pm
    It’s actually really weird. I have a 3 second fade out and then a 3 second fade in. With GPU Accel on the fade in starts dark and fades in smooth and quickly. In the rendered video the fade in is slower and feels delayed. With GPU Accel off the fade in seems like it starts off as bright white instead of black but it also fades in smoothly. The rendered video from that also fades in brighter but is still some what delayed in comparison.
  • Bob Wills
    February 26, 2019 at 11:06 pm
    General
    Complete name : D:\videos\1.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp42/mp41)
    File size : 1.56 GiB
    Duration : 3 min 40 s
    Overall bit rate mode : Variable
    Overall bit rate : 60.5 Mb/s
    Encoded date : UTC 2017-09-27 21:19:18
    Tagged date : UTC 2017-09-27 21:19:18
    TIM : 00;00;00;00
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L5.1
    Format settings : CABAC / 3 Ref Frames
    Format settings, CABAC : Yes
    Format settings, RefFrames : 3 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate : 60.4 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 (29970/1000) FPS
    Original frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.972
    Stream size : 1.55 GiB (100%)
    Language : English
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Source duration : 3 min 40 s
    Bit rate mode : Variable
    Bit rate : 125 kb/s
    Maximum bit rate : 201 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 3.30 MiB (0%)
    Source stream size : 3.30 MiB (0%)
    Language : English
  • Bob Wills
    February 26, 2019 at 11:07 pm
  • George Dean
    February 26, 2019 at 11:24 pm
    Bob, have you tried the Intel QSV render format option, and what are the results? I don’t see anything in your source media that would have caused it, it is constant frame rate, which is good. And, I happy to see you have the pixel format set to 8 bit (not 32 bit).
    Also, have you done a full reset of Vegas? Hold down the ‘Ctrl+Shift’ keys, then double left click on the Vegas desktop shortcut. check the box ‘Delete all cached application data’, and then left click on ‘Yes’. This will reset Vegas Pro to it’s installation default settings and delete the pesky build up cached application data, which sometimes causes Vegas to do strange things.
    When I have had problems, or read problems that the render is different than the preview (and the preview is running a project properties speeds), most often it is linked to the GPU processing in either an FX during preview or the render acceleration process. Not always, but usually.
    If you start Vegas and load your project, then load another instance of Vegas, go back to your project instance and select ALL in the timeline, then do ‘Ctrl+C’ to copy all the tracks and events in your project timeline, then switch over to the second instance of Vegas, and do ‘Ctrl+V’, which should paste everything in your project to this 2nd instance of Vegas, then render it out…..what are the results?
    I know this is jumping through hoops, just trying to suggest things that may lead to a solution.
  • Francois Pénzes
    March 4, 2019 at 9:09 pm
    Hi Bob
    Just curious as to what type of fade you are using. Here’s something else you may want to try on top of what George is suggesting. Look at the pic below and see which one you are using (type 1 or type 2 fade out) and try the other way. Don’t ask me why it makes a difference but I did find that in some cases it did.
    Let us know how it goes.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
