Activity Forums VEGAS Pro Vegas Not A Stable Platform
  • Vegas Not A Stable Platform
    Posted by Ken Bennett on July 24, 2010 at 5:46 am
    Looks like I may have to start looking for another NLE. I’m trying to give Vegas a chance but once I put it into full production, there are so many crashes and issues that it’s impossible to get anything edited.
    I’ve got the computer power: dual Xeon 2.8MHz, 8 cores, 16GB RAM dual channel, WIN 7 64-bit, Vegas Pro 9.0e.
    The problems: crashes when Vegas captured clips are dropped in time line (25% of the time); will swap clips in the time line with other clips from different bins upon reloading the project; will crash when adjusting clips for slo-mo or in/out points far too many times.
    My only thought is when Vegas captures clips (from HDV tape), 25% of them are being corrupted. Just wish there was more support from Sony to address all these problems. Otherwise, Vegas will die a slow death just like the Video Toaster is doing.
    Ken
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
    Magnus Wiström replied 15 years, 10 months ago 12 Members · 33 Replies
  • 33 Replies
  • Rosh Kadri
    July 24, 2010 at 6:13 am
    First i’d like to mention i do not work for sony.
    For 8 years, vegas has edited everything i threw at it. It crashed 5% of the time over several years. But through constant updates, i found most of the problems resolved. Im cutting a feature film with it right now with 1 terrabyte of P2 clips. Not a hick up. I also still work with DV tapes from capture to output and no problems either. What version are you using? Im still in pro 8 and its running smooth. Maybe its not a vegas issue, maybe a corrupt file, disk or other factors. My system mirrors yours too, windows 7, 3.2 GHZ
  • Stephen Mann
    July 24, 2010 at 6:15 am
    Can’t help you here, except to hold the door for you.
    Vegas has always worked perfectly for me here since Version 3. I can count the number of crashes on one hand, and if I discount those due to system issues (usually old drivers) or operator error, then I am left with … one. One crash in years that I couldn’t explain.
    If your system is unstable for Vegas, you won’t be very happy with Premiere, either.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Steven Talley
    July 24, 2010 at 12:54 pm
    If you want to troubleshoot the problem,
    1 Update your Video and Audio drivers to the latest. You probably have done this.
    2 Try the 32 bit version of Vegas if your running the 64 bit version. You never know!
    3 Try a previous version of Vegas like 9b, c or d.
    4 The last resort is to wipe the hard drive and start over. If it’s going to work this will be your best shot.
    Good luck
    Steve
  • Norman Willis
    July 24, 2010 at 1:58 pm
    Now there’s a helpful suggestion.
    If you’re that frustrated, why not just start with that? It seems like it would save a lot of time, in the long run. And then maybe you don’t have to buy anything.
    Norman Willis
    http://www.nazareneisrael.org
  • Kevin Mccarthy
    July 24, 2010 at 5:33 pm
    I produce a nationaly syndiicated weekly TV show in HD and with a schedule like that I can’t afford crashes. That is why I have used Vegas since version 4..It DOES NOT crash!
    There has to be something corrupt in your system. If you are using HD are you using the HD capture not the SD capture? What are you doing when it crashes?
    Perhaps you need a more consumer oriented product. Sony Vegas is definately a pro system that works all the time.
  • Ken Bennett
    July 24, 2010 at 6:22 pm
    Well, I guess I woke up a few people.
    I’ve spent my sleepless night going over my Vegas situation and reading your feedback. Don’t get me wrong. I do like Vegas when it’s working. If many say they don’t get crashes and others say do all the time, and it’s the same software version, it really leaves only 2 possible causes: the computer system or a bad Vegas disk/or download file.
    I first got Vegas Pro 8 (32bit-WIN XP) last year to start to learn it (very limited time), between all my normal editing on my “other” NLE. I didn’t have any crashes in my learning. I then got Pro 9 and went through 9.0a, 9.0b and 9.0c and upgraded to WIN 7 64-bit. I edited a 2-cam wedding ceremony using multicam with no crashes. Then I upgraded to 9.0e. At the same time I did some computer hardware changes. Removed 2 external SCSI RAID boxes, replaced with one new SATA RAID box and installed 2 new RocketRAID cards to handle internal and external RAIDs. Then I put Vegas Pro 9.0e into full production…. and the crashes started.
    Not being a computer guru, I’m thinking it may be something to do with the new RAID controllers and my internal RAID; since that’s where all my video data is located. I am in the process of cleaning off and reformating the internal RAID drive. So maybe the idea of wiping it clean and starting over is the key. Since that’s what I’ll be doing anyway.
    Now when you say “start over” do you mean recapturing everything again?
    I’m glad some of you have stable systems. Just wish I could mirror your system and have the same stability so I can get back to the creative process of editing killer videos using Vegas. (I really don’t want to or have the time to start over learning yet another NLE).
    Feedback always welcome.
    Thanks all,
    Ken Bennett
    Video Adventures
  • Norman Willis
    July 24, 2010 at 6:34 pm
    The concept is, if one has a hardware combination that was stable and worked, and one ‘upgrades’ (i.e., changes something) and now it no longer works, then go back to what worked.
    Norman Willis
  • Bradley Mowell
    July 24, 2010 at 7:10 pm
    It’s your system. Not that your system is BAD. It’s just that your system operates on a crippled platform – Windows!
    Windows would be great if it NEVER were connected to the internet.
    Mine isn’t. It runs awesome! My old, ‘malware ridden’ laptop? Not so much.
    Start with a fresh install…and NEVER plug in that ethernet cord.
    Not practical?
    Personally, I think ‘practical’ is what WORKS and not what sits there repeatedly needing fixed.
  • Kert
    July 24, 2010 at 7:56 pm
    I had freezes with 9e so I went back to 9d and the freezes stopped. JK
  • Bob Peterson
    July 24, 2010 at 8:00 pm
    It seems Vegas worked fine until major hardware changes were made. Then it started crashing. That seems to scream hardware or driver problems. Stuff that Vegas does not control. That seems like the best place to start.
Page 1 of 4
