Activity › Forums › VEGAS Pro › Vegas & MP4 files
  • Vegas & MP4 files
    Posted by Brendan Ford on September 23, 2009 at 8:20 am
    Hello,
    I have Sony Vegas 8.0 Pro, I know it’s not ideal but sometimes I need to edit MP4’s.
    I can import MP4’s but when inserted on the timeline the audio track/stream is not loaded, in fact when I check the file attributes of an MP4 it says that the audio stream can not be read.
    Can anyone tell me how I can fix this? I’m sure it’s a codec issue, but I’m not sure which codec(s) I need to install, and how Vegas can read it.
    Many thanks for your support.
    John Rofrano replied 17 years ago 2 Members · 1 Reply
  • John Rofrano
    September 24, 2009 at 10:15 pm
    Where did you get the MP4’s from? What files extensions do they have? Depending on where they are from they can use a variety of audio codecs. You might try opening one in the QuickTime Player and use the Movie Inspector (Ctrl+I) to see what codecs are being used That should tell you what you need to install.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
