Activity › Forums › VEGAS Pro › Vegas Movie Studio Platinum 9.0 Help with Audio track
  • Vegas Movie Studio Platinum 9.0 Help with Audio track
    Posted by Julia Abelle on April 21, 2009 at 10:58 pm
    Hey!
    I am making a video using a song (on separate audio track)
    Problem:
    The beginning of the song is very quite (silent) and gradually exaltates towards the culminative accord, whereupon the song takes real strenth.
    I need to raise the volume of JUST the silent part. All through it equally. I couldn’t find how to do it without touching the whole track. Moreover fade in/fade out function seems to work only for lowing the volume and apart from that applies only to the beginning and the end of the audio track.
    I might also need increase/decrease of the volume in the middle sections in the future.
    Please, any ideas?
    Mike Kujbida replied 17 years, 5 months ago 4 Members · 4 Replies
  • Rob Strobbe
    April 22, 2009 at 1:08 am
    Right-click the track and choose Insert > Insert/Remove Envelope > Volume. You’ll get a line (the envelope) that represents the volume for that track — dragging it up raises the volume, dragging it down lowers the volume.
    To affect only part of the track, double-click the envelope to add points and drag the points or the line between two points to change the volume.
    Note that anything after the last envelope point will have the volume of that point, so be sure to add a point at the end of your “silent” section so that the rest of the song doesn’t get its volume level.
    Rob
  • Julia Abelle
    April 22, 2009 at 11:13 am
    Many many thanks Rob!!! Tonight I will try to do all of this. Hope it works. Or if I still have questions I will show up again 🙂
  • Marcus Lovitt
    April 25, 2009 at 3:39 am
    I also found this tip very helpful, although I used Insert from the dropdown menu (wasn’t there when I right clicked).
    Cheers,
    Marcus
  • Mike Kujbida
    April 25, 2009 at 11:34 am
    The shortcut for this is to select the audio track by clicking it and then pressing the V (for Volume) key.
