Activity Forums VEGAS Pro Vegas & M-audio IO Digital Mixer or alternates are ??
  • Gary Kleiner
    June 14, 2007 at 4:14 pm
    Any control surface with Midi interface should work, though you may have to spend some time assigning controls if it’s not directly supported (like this one).
    Any input device with proper drivers would allow you to assign different inputs to different tracks.
    I use a Mackie Control surface and a MOTU audio I/O.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Will Standley
    June 14, 2007 at 5:25 pm
    Gary,
    I just found the Motu 8pre firewire audio Interface…
    https://www.zzounds.com/item–MTU8PRE
    8PRE 16×12 FireWire Audio Interface
    8 XLR/TRS “combo jack” mic inputs.
    1 – Are 24 bit 96 kHz converters satisfactory for today
  • Mark Moss
    June 20, 2007 at 3:25 pm
    I just started using the Presonus Firepod at 24/96 and it works wonderfully with Vegas with no latency. I’ve recorded 8 simultaneous tracks with no problems. You just need to assign the different tracks. I’ve been told that you can daisy chain as many as 3 of them together for 24 tracks, but for right now I’m only using 1.
