Activity › Forums › VEGAS Pro › vegas is weak in some things?
  • vegas is weak in some things?
    Posted by Rosh Kadri on January 20, 2008 at 5:18 am
    hello,
    just wondering, say you wanna add an effect to one small section, and apply the non real time effect, then you change your mind later, cant you undo that operation like other daw’s?
    Don Bloom replied 18 years, 8 months ago 2 Members · 1 Reply
  • Don Bloom
    January 20, 2008 at 7:58 pm
    First the video FX can be undone by simply opening the button on the bottom right of the clip and you can shut the FX off or delete it from the clip.
    For non-real time audio FXs when you do the effect it creates a “take”-therefore you can go to that audio clip and right click which brings up a menu and towards the bottom of that menu is the heading labeled “takes”-click on that and the take of that audio clip are brought to view. Click on the one you want and you’re all set.
    HTHs
    Don
