Activity › Forums › VEGAS Pro › Vegas Has Stopped Working….?
  • Vegas Has Stopped Working….?
    Posted by Tevya Washburn on October 13, 2011 at 11:20 pm
    Suddenly, whenever I try to open the project I’ve been working on, Vegas crashes! Any ideas on how to deal with this, I can’t start over on this project.
    It has happened with past versions of Vegas (you’d think they’d fix this by now), but with those, I could usually create a copy of the .veg file to fix it.
    Here’s the issue info:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0e (Build 738) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Program FilesSonyVegas Pro 10.0vegas100.exe
    Fault Address: 0x000000014019309F
    Fault Offset: 0x000000000019309F
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 10.0vegas100.exe
    Process Version: Version 10.0e (Build 738) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2011-06-29 (Wed Jun 29) 18:33:50
    –Tevya
    Tevya Washburn replied 14 years, 11 months ago 2 Members · 3 Replies
  • Jeff Schroeder
    October 14, 2011 at 12:13 am
    This might work… If your settings are to open the last project(default) go to the .veg and rename it. (Project.veg to project-old.veg) Make a new folder and move all the assets to that folder. Then get Vegas running and open the renamed project, it will ask you if you want to search for or give a new location of the each event. give it the new location for each asset and load them in one at a time, do not click the ‘other files were found in this folder’ option.
    With any luck it will bomb out on a specific file, you can repeat the process leaving that file offline, continuing with the rest and recover most of your work.
    Good luck,
    Jeff
    http://www.narrowroadmedia.com
  • Tevya Washburn
    October 14, 2011 at 10:20 pm
    Thank you! I think I remember using this solution in previous versions. I ended up just opening the project file in 32bit Vegas 10, and that worked great.
    It’s crashed a lot though. It’s comparatively bad to Illustrator for crashes (maybe worse). It’s so frustrating. I realize it’s a powerful program and is trying to do a lot of things at once, but it would sure be nice if Sony could make it more stable.
    –Tevya
  • Tevya Washburn
    October 14, 2011 at 10:37 pm
    Arrghhh! This is so frusterating!
    So I went to render the project (in Vegas 10 32bit) to send a preview to the client and it’s giving me a low memory error! So I thought, well maybe it will open in 64bit, now that it’s been modified significantly. NOPE! It froze at 72% instead of 66%:
    Extra Information
    File: C:UsersTevyaAppDataLocalSonyVegas Pro10.0svfx_video_grovel_x64.log
    File: C:UsersTevyaAppDataLocalSonyVegas Pro10.0svfx_Ofx1_1_plugin_x64-‘com.sonycreativesoftware_Filters.Stereoscopic3DAdjust’ (0, Multiple Contexts).log
    File: C:UsersTevyaAppDataLocalSonyVegas Pro10.0svfx_Ofx1_1_plugin_x64-‘com.sonycreativesoftware_Filters.Stereoscopic3DAdjust’ (0, Filter).log
    File: C:UsersTevyaAppDataLocalSonyVegas Pro10.0dx_video_grovel_x64.log
    File: C:UsersTevyaAppDataLocalSonyVegas Pro10.0dx_grovel_x64.log
    File: K:FiddlerStudiosTrent Bookslanguage book trailer.veg
    Problem Description
    Fault Address: 0x4019309F
    Fault Offset: 0x0019309F
    –Tevya
