Activity Forums VEGAS Pro Vegas cuts off last few frames of video/audio from rendered video
  • Vegas cuts off last few frames of video/audio from rendered video
    Posted by Angelo Mike on June 6, 2011 at 10:28 pm
    Does anyone know how to deal with this? I don’t know if this usually happens or if I never notice it, but I just rendered a video in which someone is talking until almost the very last frame. It was about a 4 minute clip that I rendered in MP4, and the rendered video cuts off the last few frames.
    I’m rendering the highlighted section only and have snapping on. I’m highlighting exactly what I need to. Any ideas? I lengthened the highlighted region by a few frames, which works, but is an annoying and unnecessary step.
    Also, as a side issue, when I have video fade up from black as the starting point of my video, the rendered video will first show a frame of footage from right before the fade up if the clips are next to each other. Very annoying, and I missed it on a few videos I did for clients before posting them. The solution so far is to just move the clips apart on the timeline before rendering, but I wonder if this too has some fix that involves Vegas actually working properly.
    I use Vegas 9 Pro.
    Thanks.
    Frank Stevn replied 15 years, 3 months ago 4 Members · 6 Replies
  • John Rofrano
    June 7, 2011 at 1:58 am
    [Angelo Mike] “I use Vegas 9 Pro.”
    Sounds like a bug. Are you using the latest version of Vegas Pro 9.0e?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Frank Stevn
    June 7, 2011 at 11:15 am
    Have you checked the rendered video using different video players? (WMP, VLC, Media Player Classic, QT)
  • Theo Van laar
    June 7, 2011 at 1:00 pm
    I have a similar problem wuth Vegas pro 10d.
    The clip is about 20 seconds long. I rendered to a wmv file and the audio was complete.
    https://www.vimeo.com/24673752
    Then I replaced the video part to something else and rendered again to wmv (same settings). Then the last part of the audio was missing:
    https://www.vimeo.com/24678487
    I have repeated the rendering several times, rendering the whole project (20 seconds) or just rendering a selection (the same 20 seconds). Or even extended the project. But whatever I tried, always was the last part of the audio missing.
    Theo
  • Angelo Mike
    June 7, 2011 at 8:40 pm
    I believe I have 9e. I just tried installing 9e to make sure, and it said that I already have Vegas Pro. So I guess that means that I have it.
  • Angelo Mike
    June 8, 2011 at 10:37 pm
    I’ve been playing videos with VLC Media player. I tried it with WMV and it plays fine, so I guess the video and audio are fine, it’s just VLC.
    Has anyone else experienced this problem?
  • Frank Stevn
    June 8, 2011 at 10:47 pm
    Yes Angelo, I had the same problem with VLC.
    That is why I don’t use it to check rendered videos.
