Activity Forums VEGAS Pro Vegas Crashing when going to Audio tab in render options
  • Vegas Crashing when going to Audio tab in render options
    Posted by Andrew Turner on February 3, 2010 at 12:54 pm
    Just wondering if anyone has come across this problem before. I am trying to render to a quicktime file. I choose custom and then select the audio tab which causes vegas to crash. This only happens when i choose .mov, customise and then select the audio tab. All other export formats are ok with audio.
    I have tried re-installing quicktime but this has not helped. Has anyone else come across this before.?
    Cheers
    Andrew Turner
    Mike Kujbida replied 16 years, 7 months ago 2 Members · 6 Replies
  • Mike Kujbida
    February 3, 2010 at 1:30 pm
    Andrew, I’m having the same problem.
    I’m using the latest version of QuickTime so I’m not sure if that’s the source of the problem or not as I haven’t bothered rolling back to an earlier version to test it.
  • Andrew Turner
    February 3, 2010 at 1:57 pm
    Funny thing is Mike is that it was working. It’s a real mystery.
  • Mike Kujbida
    February 3, 2010 at 2:02 pm
    Andrew, I’m running QuickTime 7.6.4
    Is yours the same (or newer) version?
    Did it stop working for you after you did an iTunes update?
    I’m asking because that’s when a lot of us started having problems with importing mp4 files into Vegas.
  • Andrew Turner
    February 4, 2010 at 5:32 am
    Hi Mike. I was running the latest Quicktime 7.6.5 but unsure what the original version was before I had these issues.
    I thought updating to the latest may solve the issue.
    I have done some testing rolling back to 7.6.4 and still had the same issue. I just finished re-installing vegas and still have the same issue. I’ll keep rolling back through quicktime versions to see if thats the issue.
  • Andrew Turner
    February 4, 2010 at 5:51 am
    UPDATE: i just rolled back to quicktime version 7.6.2 and I can now select the audio tab without vegas crashing.
  • Mike Kujbida
    February 4, 2010 at 9:37 am
    Thanks very much for the update Andrew.
    Now to see if that will cure an unrelated problem I have encoding to QuickTime.
