Activity Forums VEGAS Pro Vegas capturing not seperating clips in capture
  • Vegas capturing not seperating clips in capture
    Posted by Shawn Bossick on January 15, 2008 at 7:13 pm
    Hi I’m having a problem that I didn’t used to have. I’m using Vegas 7.0b, WinXPSP2 and have the Panasonic DVX100A that I’m dumping footage from via firewire. The problem I’m having is that it’s dumping the footage into one huge clip rather than allowing me to seperate it into several different clips during the capture. Anyone?
    Thank you,
    Shawn Bossick
    Shawn Bossick replied 18 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Edward Troxel
    January 15, 2008 at 9:18 pm
    Is the clock in the camera set?
    Edward Troxel
    JETDV Scripts
  • Shawn Bossick
    January 15, 2008 at 10:29 pm
    The date and time clock were turned off to not show date and time on film. As far as the timecode generator is concerned its set at factory defaults for the last 4 years.
    I thought I once saw a command in Vegas, that stated if you wanted to capture your film in one large clip or seperate indivdual clips, for the life of me, I can’t find that command or option if it exists.
  • John Gordon
    January 16, 2008 at 2:11 am
    enable scene detection in capture preferences??
    John Gordon
  • Shawn Bossick
    January 16, 2008 at 4:55 am
    Yes, it is enabled.
  • Mike Kujbida
    January 16, 2008 at 11:45 am
    [Shawn Bossick] “The date and time clock were turned off to not show date and time on film.”
    Just so you know, that’s not what Edward was asking.
    Is the internal clock set?
    If not, it may be time to replace the button-sized battery that’s responsible for this feature.
    Timecode is derived from this internal clock.
    The date/time display is a completely different issue.
  • Shawn Bossick
    January 16, 2008 at 4:22 pm
    Thank you very much, I will take that approach and replace the battery.
    Shawn Bossick
  • Shawn Bossick
    January 16, 2008 at 4:23 pm
    Shawn Bossick
  • Mike Kujbida
    January 16, 2008 at 4:35 pm
    Remember to set the DVX’s internal clock after you do that.
    It won’t solve your current problem as the time data wasn’t there to begin with but you’ll be OK in the future.
    BTW, this applies to ALL miniDV camcorders.
  • Shawn Bossick
    January 16, 2008 at 4:57 pm
    Thank you very much Mike and Edward for your help.
