Activity Forums VEGAS Pro Vegas capture not recognizing interlace
  • Vegas capture not recognizing interlace
    Posted by Don on November 14, 2005 at 4:15 pm
    I am using a JVC GY-DV500. When I capture tape from it, Vegas capture identifies the video as progressive, but it is actually interlaced, bottom field first. When I capture using a Datavideo DAC100, the video is correctly identified as being 30i, bottom.
    Any thoughts? Thanks.
    Mike Kujbida replied 20 years, 10 months ago 2 Members · 1 Reply
  • Mike Kujbida
    November 14, 2005 at 11:35 pm
    The only thing that comes to mind is to make sure your project properties are set correctly. I’ve captured from my GY-DV550 several times and it’s always worked properly.
    Mike
