Activity Forums VEGAS Pro Vegas Capabilities: Can it do this….
  • Vegas Capabilities: Can it do this….
    Posted by Matt Green on May 21, 2008 at 5:56 am
    I have limited professional experience with softwares such as Vegas, however, I’m looking for a product that will allow me to create the following desired effect:
    Using default Premiere effects/macros or 3rd party plug-ins, is it possible to use the volume or frequencies of an audio track to manipulate the colors/palette of a video? For instance, low volumes result in a blue overlay while highs are red with other volumes represented dynamically by the range between the two set colors selected. I’m looking for a completely automatic application of this effect as basic keyframing simply won’t produce the accuracy or detail that I require.
    Douglas Spotted eagle replied 18 years, 4 months ago 3 Members · 2 Replies
  • Rasmus Mauritsen
    May 21, 2008 at 1:14 pm
    I think you need After Effects mate. Check out http://www.videocopilot.net or http://www.maltaannon.com. They’ve done some tutorials on extracting data from audio-tracks for use in effects. You might be able to use them!
    Best regards!
    -rasmus, denmark
  • Douglas Spotted eagle
    May 21, 2008 at 1:23 pm
    Unfortunately, there is nothing in Vegas, nor a third-party plug that will do this. Extracting the audio for a tool like Combustion or After Effects is easy, but you’ll need one of those tools to create the effect you’re seeking.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
