Activity › Forums › VEGAS Pro › Vegas Backgrounds
  • Vegas Backgrounds
    Posted by Tom Waters on June 16, 2009 at 3:04 pm
    I have a vector logo created in Illustrator. I want to lay it on top of video with a transparent background. I can’t seem to lose the white background. Thanks in advance.
    Tom Waters
    Jeremy Rasnic replied 17 years, 3 months ago 3 Members · 2 Replies
  • John Rofrano
    June 16, 2009 at 4:32 pm
    Right-click on the event that holds the PNG and select Properties and then Media Tab and make sure the Alpha channel is set to something other than none. Using straight (unmatted) is usually best for PNG’s. If this is the case, then are you sure you save the PNG with a transparent background in Illustrator? If yes, then are you sure the white isn’t part of the file? Go back to Illustrator and remove the white so that only the Logo and transparent background remains and then export that as a PNG with transparency.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeremy Rasnic
    June 16, 2009 at 8:51 pm
    Or, if you have the creative suite that contains Fireworks you can simply save it as a fireworks file (png) and it will show up automatically with a transparent background in Vegas.
    j razz
    https://www.jrazzcreations.com
