Vegas adding sound-pop at end of rendered audio
Posted by Musta Klaki on February 6, 2014 at 1:06 amI’ve had this issue for a while, it comes and goes. In Sony Vegas Pro 10, there is always an audio pop at the end of my rendered audio.
https://imagizer.imageshack.us/v2/1119x316q90/545/hel2.png
The above track is what I rendered from. I took the rendered piece and put it on the bottom track. That piece at the end there is the pop. No matter what, it always adds this little pop to the end after each render. I have no idea why it does this, and it does it for all audio formats.
Help?
Musta Klaki replied 12 years, 7 months ago 3 Members · 6 Replies -
Graham Bernard
February 6, 2014 at 4:03 amI’ve never seen VP of any version ADD an extra audio EVENT like that. Truly odd. O… K… What you are showing us is just 1 second if render? Yes? It looks like 30 frames in a 29.97 project? Yes? Firstly render something longer, say at least 1 minute? Do you get the same?
What I also see, even at 1 second, is that the waveforms do NOT match up. Why is that? Initially that would make me think that the render process is producing a mismatch of sampling and render. I can get ‘pops’ when the project is 44 but I’ve had 48 Media. Even still, this doesn’t explain that additional Audio, 1 frame, Event!?
So, initial thoughts, which may trigger some thoughts in others:-
1] This is truly Odd! An additional 1 frame, SEPARATE Event.
2] Mismatch of sampling.The waveforms don’t match-up. What are your Project Settings for Audio and your Event Sampling rates? And the details of your render Template.
3] Need a longer sample to confirm or deny the exact, sensible Evidenced-Based results. Can you place a 2 minute sample to view.
Ultimately I don’t understand that extra separate Event?
Interesting.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Graham Bernard
February 6, 2014 at 4:29 amOn further view, that sample is 29 seconds long. Yes? Even so, that extra Event is odd.
I’m now thinking you’ve chosen to render something close to or on the 29 frame Event edge. Is the correct? Mismatching is now what I’m thinking. Even still, that extra event? Odd.
Grazie
Musta Klaki
February 6, 2014 at 5:27 amIf by extra event you mean the part on the bottom track that is spliced, I did that to show where the pop was.
Here are my video project settings: https://imagizer.imageshack.us/v2/430x600q90/849/y0ly.png
Audio project settings: https://imagizer.imageshack.us/v2/434x602q90/842/ma1s.png
Render settings: https://imagizer.imageshack.us/v2/887x389q90/827/7pl6.png
Do frames matter? I’m not rendering this alongside any video, this is strictly audio editing.
EDIT: I rendered again and unchecked “Save project markets in media file”.
The pop is gone… this is too strange. I don’t think this is completely solved, I’ll test some moreEDIT 2: Don’t think that fixed it. It seems fixed in vegas, there’s no physical peaks in the sound waves. However, in some players, it will have a pop at the end, like when you skip randomly throughout a song while its playing, and you get that popping noise. Maybe that’s a computer issue, but this rendering thing is still annoying.
Graham Bernard
February 6, 2014 at 6:20 am_______________________________________________________________
[Musta Klaki] “If by extra event you mean the part on the bottom track that is spliced, I did that to show where the pop was.”
_______________________________________________________________O…K… So, what does the WHOLE bottom track look like without the “splice”? I would like to see the ORIGINAL above the RENDER, no “splice”.
What is the Format of the Audio Media from which you are rendering?
Grazie
Steve Rhoden
February 6, 2014 at 6:22 amStrange, have never heard of something like that before.
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Musta Klaki
February 6, 2014 at 9:31 amI received the audio in oggvorbis format. I noticed a popping noise at the end, and removed it. When I rendered the fixed version without the pop, I put it back into Sony Vegas Pro 10 to see if the pop was removed successfully. When put back into sony vegas to compare the two, the pop persisted, yet it was a different pop.
When I render to MP3, the pop does not show up in the end. It is only showing for oggvorbis. Issue is, I need the format to be in oggvorbis, being it is looping audio and audio does not loop properly in other formats. Does Sony Vegas just not like oggvorbis or something?
Top track is original, bottom is “fixed”
https://imagizer.imageshack.us/v2/1360x371q90/594/1n6f.png
