Activity Forums VEGAS Pro Vegas 9.0c Will Not Render
  • Vegas 9.0c Will Not Render
    Posted by Ken Bennett on February 17, 2010 at 7:51 am
    I’m about to give up on Vegas. I don’t buy the “running low on memory” any more. I upgraded to 9.0c in hopes I could render more than 30 minutes before I get this message of running low on memory because now it will only render 2 minutes before I now get the “running low on memory” error. I can’t go back to 8.0 with this project becuase 8.0 doesn’t accept 9.0 veg files. If someone can tell me how to downgrade back to 9.0b or 9.0, let me know. Because I was at least able to render 30 mins with 9.0b.
    So, until someone can tell me how to reconfigure my computer to run Vegas, and access all 4GB of my memory, I may have to abandon it until I can have the computer rebuilt and loaded with WIN 7 and running 64bit and accessing ALL my memory.
    As a reference, I never had any low memory issues running any other software on this computer. Even running Lightwave and all CS4 products.
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
    Theo Van laar replied 16 years, 6 months ago 4 Members · 3 Replies
  • John Rofrano
    February 17, 2010 at 11:16 am
    Uninstall 9.0c and install 9.0b. The trick is to uninstall the newer version first.
    Did you try setting the rendering threads down to 1? Did that help? When you go into the Windows Task Manager, how much memory does it say is free?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    February 17, 2010 at 12:07 pm
    If you no longer have it, you can get 9.0b at https://download.sonymediasoftware.com/current/
  • Theo Van laar
    February 17, 2010 at 3:34 pm
    ‘I’m about to give up on Vegas. I don’t buy the “running low on memory” any more. I upgraded to 9.0c in hopes I could render more than 30 minutes before I get this message of running low on memory because now it will only render 2 minutes before I now get the “running low on memory” error.’
    Never give up when you are so close to the finish…
    Did you try network rendering? Even if there is no network available for rendering, selecting this option (in the render tab) usually avoids the low memory error message, resulting in a normal rendering process.
    Theo
