Activity Forums VEGAS Pro Vegas 9 problem
  • Vegas 9 problem
    Posted by Mike Hite on September 12, 2009 at 12:00 am
    Problem:
    Whenever I play a video clip then stop the preview and i hit F3 or F9 to cycle individual frames to split. It has a very weird problem of overlapping frames. It repeats the same frames I just went thru atleast one or two more times making it impossible to cut on the right frame.
    The problem I am having is hard to explain (Its like when I hold down f3 it repeats the same frames atleast once or two times more than what it should be cycling thru as I watch the preview window) Vista 64-Bit SP2 Ultimate never did this, but my windows 7 64-Bit Ultimate RC Build 7100 does this.
    I figure “Hey why not start using windows 7. It will be out in stores October 22, 2009!”
    I could go back to vista, but I don’t really want to so can anyone tell me how to fix this issue that occurs with windows 7 RC?
    Does anyone know how to fix this?
    Jeremy Rasnic replied 16 years, 11 months ago 2 Members · 1 Reply
  • Jeremy Rasnic
    September 18, 2009 at 2:03 pm
    I don’t have a clue on how to fix it. As you know, Vegas is not supported under Windows 7 at this time. Once it is, I am sure the issue will be addressed, but currently you are working with unsupported host software and that my friend is one of the casualties of being cutting edge 🙂
    I’m sure that’s not the answer you want to hear. On the other hand, can you utilize another method: use the zoom wheel to zoom in and then use the arrow keys to step through the frames one at a time?
    j razz
    https://www.jrazzcreations.com
