Activity › Forums › VEGAS Pro › Vegas 9 Pro & *.mp4 videos?
  • Vegas 9 Pro & *.mp4 videos?
    Posted by John Gregoriades on September 1, 2010 at 4:09 pm
    Hi again,
    Occasionally I shoot videos with a Nokia N95 8G Phonecam, which outputs *.mp4 files.
    They work OK with Vegas 7 and Vegas 9. But I tried a Vegas 9 Pro and the video was a simple black screen. (The audio was OK.) No video at all, so I tried several such clips on the Vegas 7 and they worked fine.
    What am I doing wrong with V9 Pro?
    Thank you
    John
    (p.s. browsing is disabled for Vegas to go directly to the Nokia. So I copied-pasted the video file on Windows – My videos and tried to import it into Vegas. But when placed on the timeline….black!)
    John Rofrano replied 16 years ago 5 Members · 10 Replies
  • 10 Replies
  • John Rofrano
    September 1, 2010 at 11:03 pm
    Are you using the 64-bit version of Vegas Pro 9 or 32-bit?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Gregoriades
    September 2, 2010 at 5:01 am
    I have no idea, it belongs to a friend, will try to find out when I visit next week. Is the version important for this issue?
    John23GR
  • Alana Barquero
    September 2, 2010 at 5:21 am
    You can’t put mp4’s into the timeline I have tried before as well it has to be a different format. Like avi but it seems that mp4 won’t work in SV.
  • Edward Troxel
    September 2, 2010 at 3:37 pm
    [Alana Barquero] “You can’t put mp4’s into the timeline I have tried before as well it has to be a different format.”
    Now that’s just plain silly. My son has a GoPro camera that shoots MP4 files. I can drop them straight onto the Vegas timeline – no issues at all.
    Edward Troxel
    JETDV Scripts
  • John Rofrano
    September 3, 2010 at 4:15 am
    Well… the 64-bit version will only be able to read videos if your have a corresponding 64-bit codec installed. Since Vegas 7 was 32-bit, it can read video that the 64-bit version cannot. So if the previous version of Vegas Pro 9.0 was 32-bit and this one is 64-bit it might explain why the video is black now but use to work fine.
    Have you tried changing the preview settings? The Movie Studio version of Vegas has problem where video turns black and if you change the preview setting it magically re-appears.
    ~jr
  • Dave Haynie
    September 3, 2010 at 4:30 pm
    It’s a matter of CODECs, for sure.
    .MP4 needs a CODEC, or DirectShow filter in Windows-speak. These come in 32-bit and 64-bit flavor, too. So it’s quite possible to see .MP4 in a 32-bit version of Vegas, but not in a 64-bit version. And all bets are off if you move to a different PC.
    With the proper system support, Vegas handles MP4 files just dandy. I have edited them many times.
    -Dave
  • John Gregoriades
    September 12, 2010 at 4:15 am
    Thank you all, for your most helpful replies. I am not up to speed on Codecs. Or on 32 or 64 bits. So two questions, please:
    1. How can one tell which, 32 or 64 is the Vegas program?
    2. How does one obtain a codec: buy, free download, or? and how does one “install” it, via Vegas, on its own via Windows as a separate program or…?
    Thank you again
    John
    John23GR
  • John Rofrano
    September 12, 2010 at 5:45 pm
    There are lots of ways to tell:
    (1) The 64-bit version can only run on a 64-bit operating system so the first clue is are you using Windows 7 64-bit or Vista 64-bit. If not, you are using the 32-bit version.
    (2) When you start Vegas Pro the 64-bit version will say, “Vegas Pro 9.0e (Build 1146) 64-bit” while the 32-bit version just says “Vegas Pro 9.0e (Build 1146)”
    (3) If you have an icon on your desktop it will say “Vegas Pro 9.0 (64-bit)” if it’s 64-bit
    It depends on the codec. Some are free and others you have to purchase. Most will come with instructions on how to install them. Vegas will see them if they are VFW codecs and the same architecture (32-bit or 64-bit) as Vegas.
    ~jr
  • John Gregoriades
    September 13, 2010 at 3:59 pm
    Thank you, John.
    I checked as you suggested, it says 9.0b and no mention of 64. Further his Operating system is a dated Windows XP.
    I guess that pins it down to a 32.
    John23GR
  • John Rofrano
    September 13, 2010 at 9:17 pm
    Yes it does. Now you need to get him to update to 9.0e so you can get all the bugs that were fixed in 9.0c and 9.0d and all the new features added to 9.0e!
    ~jr
