Vegas 8c & Panasonic HD — vegas crashes
Posted by Kit Cassingham on November 21, 2008 at 11:30 pmI have Sony Vegas Movie Studio 8.0c. It’s worked with my previous Panasonic HD cameras (one tape the other card) for awhile now. But I upgraded my camera to the HDC-SD100 and now can’t open or play most clips.
I lowered the camera’s “resolution” (1440×1080) to the lowest possible which only makes Vegas crash slower (it takes a bit longer for it to crash). What do I need to do to be productive with this camera?
Peter Popovici replied 16 years, 4 months ago 5 Members · 13 Replies -
Douglas Spotted eagle
November 22, 2008 at 2:10 amAre you Xferring the files to your HDD first? Or trying to edit straight off the camera?
Douglas Spotted Eagle
VASSTCertified Sony Vegas Trainer
Aerial Camera/Instructor -
Kit Cassingham
November 22, 2008 at 7:14 pmI’m transferring to my HDD first. Some short clips will play, but anything longer than short will crash Vegas.
Mike Fajdiga
April 19, 2009 at 7:17 amI own a Panasonic HDC-SD100 and Vegas Pro. I have been trying hundreds of options in Vegas and in the camera for five months now. I have had over 20 customer support sessions on this issue with Sony Support. There is simply no solution to this while Sony refuse to acknowledge that 8C and Panasonic AVCHD is simply incompatible. My longest succesful render in Vegas is 30 seconds. Anything more than this will crash the application. Sorry, I want a solution too.
Sony only real suggestion was to convert every clip to Windows Media (wmv) at low resolution (SD)as a work around!!! How rediculous. Why did I buy an HD camera and an HD editor? Thousands of dollars down the drain.
Mike
Dave Edwards
May 19, 2009 at 7:24 amHi,
I too use the Panasonic HDC-SD100 and Vegas Pro 8c.
I am unable to render 1920 x 1080 HD but can create .wmv at 1440 x 1080 – HD but not full HD.
I have been experimenting with the trial version of Vegas Pro 9 which renders more material before crashing with an out of memory error.
Is this similar to your experience?
Kit Cassingham
May 19, 2009 at 12:34 pmVegas Platinum 8d took care of my problems. Upgrading to 9 soon.
Mike Fajdiga
May 19, 2009 at 12:42 pmI have fixed the problem but it’s a big fix. I have upgraded to Vista 64 bit operating system and have loaded Vegas Pro 8.1 (64-bit). It works perfectly without crashes. I can render at 1440X1080 (the best available option in Vegas for AVCHD) and can burn a blu-ray at 1920X1080 without any problems. 32 bit operating systems simply don’t allow enough memory for AVCHD rendering (maximum 3GB). It’s not actually a Vegas Pro fault however Sony should be more up front and state that 32-bit does not allow for AVCHD rendering at HD. Hope this helps.
Dave Edwards
May 19, 2009 at 2:44 pmHi Mike: that’s very helpful, but does Vegas 8.1 still prevent you from reaching 1920 x 1080 even given your 64bit OS?
Mike Fajdiga
May 19, 2009 at 9:30 pmYou can only render at 1440×1080 but you can burn a blu-ray at 1920×1080 in Version 8.0c. A bit strange!! Below is the response I received from Sony Support last night:
Hi Mike,
Thank you for contacting Sony Creative Software. It is not possible to render above 1440×1080 in Vegas Pro 8.1. It is not possible to render 1920×1080 AVC in Version 8.1. To answer your second question, the functionality of Vegas Pro 8.1 and it’s audio file displays for 5.1 audio is indeed different from the Vegas pro 8.0c and Vegas Pro 9.0 software, however, this functionality cannot be adjusted in Vegas Pro 8.1. This functionality in Vegas Pro 9 was set back to our previous functionality in Vegas Pro 8.0 rather than the Vegas Pro 8.1 update.
The best option available for you to obtain the ability to render in 1920×1080 AVC and see your 5.1 audio as six channels placed into separate events with the panner set centrally, would be to upgrade from your version 8.0c to the Vegas Pro 9.0.
Dave Edwards
May 21, 2009 at 6:43 amI’ve been trying to render in 1920 x 1080 using the trial version of Vegas Pro 9: it begins, but on my 32bit system rendering a 30 minute item it fails after around 30% complaining that there is insufficient memory (although it didn’t actually seem to be using the available memory,- 3Gb). Do Sony mean the 64bit version (in Mike’s post)? Has anyone succeeded in rendering 1920 x 1080 AVCHD without error?
Mike Fajdiga
May 21, 2009 at 9:06 pmVegas Pro 8.1 or Vegas Pro 9.0 (64-bit) work perfectly under Vista 64-bit. I am rendering 1920×1080 AVCHD from my Panasonic SD-100. Length of render in excess of 30 minutes witout error and quite fast (less than 45 minutes!). Vegas Pro 9.0 32-bit crashes even under Vista 64-bit. It’s true that it crashes stating insufficient system memory even though the System Monitor reports only 2.1GB during render. AVCHD amd 32-bit just doesn’ work.
Spend the $150 on upgrading to Vista 64-bit and all your worries will be gone. I am running 6GB memory, Intel i7 quad processor.
