Activity Forums VEGAS Pro Vegas 8b lockup on HDV render
  • Vegas 8b lockup on HDV render
    Posted by Charles Avanti on June 24, 2008 at 3:35 pm
    My first use of V8b and first HDV edit project and my first Vegas render lockup ever since V4.
    I’m trying to render a 30 second video intro in V8b, in took 2 hours to get 39% complete, then hung there for another 2 hours doing no progress. I had to shut it down with Task manager. This is the error report from Task Manager:
    Description:
    A problem caused this program to stop interacting with Windows.
    Problem signature:
    Problem Event Name: AppHangB1
    Application Name: vegas80.exe
    Application Version: 8.0.0.217
    Application Timestamp: 47852d9a
    Hang Signature: 79d5
    Hang Type: 6144
    OS Version: 6.0.6000.2.0.0.768.3
    Locale ID: 1033
    Additional Hang Signature 1: 164e5eec46a6b56cda74da5e6d24afb3
    Additional Hang Signature 2: 1b1d
    Additional Hang Signature 3: c5d056a9e25dcc452039720e32fec6b5
    Additional Hang Signature 4: 79d5
    Additional Hang Signature 5: 164e5eec46a6b56cda74da5e6d24afb3
    Additional Hang Signature 6: 1b1d
    Additional Hang Signature 7: c5d056a9e25dcc452039720e32fec6b5
    Read our privacy statement:
    https://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
    My system setup is:
    Vegas 8b, in 8 bit mode
    Vista 32 bit
    4 gig memory
    Quad core Q9300
    NO virus protection
    NO email or web browsing
    New computer
    Up to date BIOS, software, and drivers
    Very few other programs installed
    Fresh and only install of Vegas 8b trial version
    No screen savers, background programs, no hibernate, or energy saving options.
    No M2t clips on the timeline, just QT HD Jumpbacks, masks, TGA sequence, alpha AVI’s.
    Total of 23 video tracks, and 2 audio tracks.
    Any help would be appreciated.
    Charlie
    Charles Avanti replied 18 years, 2 months ago 2 Members · 4 Replies
  • Jeremy Rasnic
    June 24, 2008 at 3:46 pm
    What format are you encoding to for output? Attempt doing an encode in an avi wrapper so that you can pick up the encode where it left off and then continue. I think the issue may lie with the mov files but I am unsure. Using the juicer, is there a way to export them as avi files with alpha channel? I haven’t used the juicer in a long time.
    Also, based on the file types, masking and amount of items on the 30 second timeline, it does not suprise me that it is taking a while to encode. You may be running into ram issues. If you are willing to try it again, watch your pagefile usage under the task manager and see if the level climbs and plateaus at your maximum page file usage when the encode hangs.
    Let us know.
    j razz
  • Charles Avanti
    June 24, 2008 at 4:16 pm
    I was rendering to a “new track”
    Type= Video for Win. AVI
    Template: HDV 1080-601 intermediate
    I have 4 gig of RAM installed and it tested OK.
    I know how to look at Task Manager and Monitor, but where do I find the pagefile usage and what do I look for? Thanks.
    B-T-W I did send this to SONY.
    Charlie
  • Jeremy Rasnic
    June 24, 2008 at 6:03 pm
    The page file usage is denoted as PF and it should be located right below your cpu usage graph.
    Instead of rendering to a new track, try “File”–>”Render As” and then choose your settings there.
    j razz
  • Charles Avanti
    June 24, 2008 at 7:10 pm
    I may have stumbled upon the solution…..again. I found since using/fighting with computers since 1980, sometimes when your up against the wall, it’s worth trying the wild card long shot idea.
    This is what I changed:
    1. I deleted 3 video tracks that were set up as parent/child that had no video on them since I decided on an edit change.
    2. I used the default name of the new track “new track 2” instead of naming it “TITLE test” or something. I seem to remember something about not naming tracts “Title”, or some such name.
    3. I let Windows Task manager- performance run on top of Vegas as it rendered.
    B-T-W it rendered in 1 hr. 38 minutes this time.
    4. I held my mouth tight to the right.
    it rendered fine.
    THEN, I added another video track with alpha and tried to render the whole project again, leaving the good part of “New track 1”.
    This time I didn’t leave Windows Task manager- performance run on top of Vegas as it rendered, and somewhere near the end Vegas just closed altogether leaving me with no newly rendered project.
    So, I tried again, this time with Windows Task manager- performance run on top of Vegas as it rendered. IT RENDERED FINE.
    I noticed the CPU ran at 100% both times, but memory was about 2.20mb on the first successful render, and about 1.83mb on the second.
    For what it’s worth……..your mileage may vary.
    Charlie
