Activity Forums VEGAS Pro Vegas 8.1 / Vista 64 trial
  • Norman Willis
    January 20, 2009 at 6:20 pm
    Quote: by adam rose esq. on Dec 5, 2008 at 4:18:26 pm
    been using 8.1 on V64 business since it came out. Have 8c but hardly use it. no problems with .mov or any other file, so far.
    End quote:
    Hi Adam.
    Did you install the Quicktime 32?
    I installed Vista 64 Ultimate on a new machine, and then installed 8.1. Vegas 8.1 wants Quicktime and gives me a download link, but then when i go to download it, it recommends not installing the 32 bit Quicktime.
    Should I image my C drive, and then go ahead and install QT32? or is there some other preferable workaround? Does anyone know?
    Thank you,
    Norman
    Norman Willis
    servant@nazareneisrael.org
    http://www.nazareneisrael.org
  • Adam Rose esq.
    January 20, 2009 at 8:08 pm
    I just went ahead and installed it. Can’t remember any problems relating to being 32bit…….
  • Norman Willis
    January 20, 2009 at 8:17 pm
    Thanks.
    I think they just released a 64-bit version, like, seconds ago.
    I just uninstalled the 32-bit, and am rebooting.
    Let’s hope it works!
    Norman Willis /
    servant@nazareneisrael.org /
    http://www.nazareneisrael.org /
    Re-establishing the original faith of the Apostles
  • Norman Willis
    January 20, 2009 at 8:25 pm
    it works!
    Quicktime 64 is out!
    Norman Willis /
  • Shafiq Khokhar
    April 15, 2009 at 4:14 pm
    So did anyone figure out how to use 8.1 trial on vista 64 yet…? because i’m having the same serial key issue.
  • John Rofrano
    April 15, 2009 at 6:12 pm
    I don’t believe their is a trial of Vegas Pro 8.1. You can use the trial of Vegas Pro 8.0 to see if you like the program. Once you buy it, you can use the 64-bit version which is exactly the same as Vegas Pro 8.0b. (note: Vegas Pro 8.0c is the latest version so 8.0c is actually newer with more functionality than 8.1.)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
Page 2 of 2
