Activity Forums VEGAS Pro Vegas 8.0 keeps freezing while rendering
  • Vegas 8.0 keeps freezing while rendering
    Posted by William Terrio on January 7, 2010 at 9:55 pm
    I am trying to make multiple WMV videos into a single WMV clip. Every time I render it, at around 86%, Vegas with either give me some giant error, or close itself without any warning, or freeze without any error.
    I don’t think the problem is my PC, since I have made about 80 videos before with Vegas, some loaded with special effects. The video I am trying to make has no effects, and is just under 10 minutes long. I’ve tried different WMV rendering modes, but it still freezes.
    I don’t want to render in a different format, because it has to fit on youtube, and I don’t want quality to suffer.
    I tried rendering just the section I thought it was freezing at, and it rendered just fine.
    I had this happen once before, and I upgraded to Vegas 9.0 and remade the whole video, but then 9.0 started giving me trouble with effects not showing up, so I went back to 8.0. I’ve been fine for a while until now again.
    Please help me. Thank You.
    D. Eric franks replied 16 years, 8 months ago 3 Members · 2 Replies
  • Ian Newland
    January 8, 2010 at 12:33 am
    Try rendering the WMV files to individual avi files first before dropping them on the vegas timeline. This should solve your problem.
    Cheers Rambo
  • D. Eric franks
    January 9, 2010 at 1:42 am
    If it is crashing at exactly the same point, you can just create a selection area (loop region) and render out a second or two of that spot as an intermediary and insert that back into the project with frame-accurate positioning and then do a normal render. I have solved quite a few trouble spots this way, even ones that don’t have a cause I can figure out.
    I’d use AVI with the Lagarith codec for this purpose.
