Activity Forums VEGAS Pro Vegas 8.0 Crashed
  • Vegas 8.0 Crashed
    Posted by Matt Paul on September 15, 2008 at 5:27 am
    When I try to add video clips to the video track, sometimes Vegas 8.0 crashes. I get the usual MS Debug message and then it shuts down. The clips play fine on the camera so I do not believe the original recordings are corrupt. I simply avoid using the clips that crash my system. My concern is eventually, the corrupt/crash clip will be the one I need for my production and can not simply be ignored. Has anyone had similar problems? Does anyone know a way to prevent this?
    Matt Paul replied 18 years ago 2 Members · 2 Replies
  • Steve Rhoden
    September 15, 2008 at 3:56 pm
    The only quick work around i could recommend to do in the
    meantime..since those clips are so vital, is to convert them
    in another application that you have that can read them…to a
    quicktime format that vegas can start working with them.
    But you did not mention which format it is or which camera you are
    working with.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
  • Matt Paul
    September 20, 2008 at 3:29 am
    Thanks for the advice. The problem seems to be limited to only 3 short clips. Hopefully it is a one off thing.
