Activity Forums VEGAS Pro Vegas 8 won’t recognize the Aja Xena LH
  • Vegas 8 won’t recognize the Aja Xena LH
    Posted by Jeron Coolman on November 20, 2007 at 8:18 pm
    I can’t get Vegas 8a to recognize the Aja Xena LH in my editing machine. I’ve been going back and forth with Sony tech support, but I haven’t gotten anywhere, so I thought I’d try here to see if anyone else had the same problem.
    The symptom is that I never see “Aja Video Device” in either drop down for Preferences->Preview Device or Capture Preferences->Device.
    The Aja Xena LH has been working great on this machine with Premiere Pro and the Aja Machina capture utility, so I doubt it is some sort of hardware conflict or problem.
    If I install Vegas on another machine that doesn’t have an Aja card, it has “Aja Video Device” as an option on both of the drop downs.
    I’ve uninstalled all software that uses the Aja card and reinstalled Vegas. Is there some sort of trick like maybe I’ve got a .DLL unregistered or in the wrong place?
    Any ideas?
    Jeron
    Jim Macmorran replied 17 years, 11 months ago 2 Members · 4 Replies
  • Jim Macmorran
    September 16, 2008 at 10:56 pm
    When I upgraded from vegas 7 to 8, i had the same issue. In fact, i still have 7 installed on my PC, and it recognizes the xena card just fine and works correctly. My current workaround is to capture with 7 and playback with 8 using the Canopus as the output device. I know i’m not getting the best visual output, but im’ just an audio guy and only need “good enough” video monitoring. The important thing tho, is, that when I render for client dubs, uploads, etc, i’m using the much better captured video for the render.
    i went back and forth with sony and the only suggestion they had was to make sure i had the most recent version of .NET framework, which I do. I’ve reinstalled drivers and .NET multiple time to no avail. Have you gotten anywhere with this issue?
    Thx.
    jmm in STL
  • Jeron Coolman
    September 17, 2008 at 3:38 pm
    I went back and forth for almost a year with Sony and got absolutely nowhere.
    I couldn’t get anyone at Sony to tell me they have actually seen Vegas work with the Xena. I gave up and went back to Premiere Pro.
  • Jim Macmorran
    September 17, 2008 at 3:58 pm
    thx for responding. I had this discussion on the sony vegas forums. They were helpful and finally said they had Vegas 8 running with a xena board, altho a slightly diff. one than i was using. Oh well. It doens’t make sense tho, that it works with 7, which is still installed, and doesn’t work with 8.
    sigh.
  • Jim Macmorran
    September 19, 2008 at 7:48 pm
    I just installed 8.0c. The aja video device now shows up in the pulldown window for preview devices.
    woo hoo.
    jmm in STL
