Activity › Forums › VEGAS Pro › Vegas 8 HDV capture problem
  • Vegas 8 HDV capture problem
    Posted by Karl Soehnlein on January 6, 2009 at 2:35 am
    I need to resolve this issue urgently:
    I am capturing HDV (720/24p) footage directly from my JVC HD100U camera to Vegas (Win XP) in .m2t format. The original footage is fine (looks and sounds OK on the camera), so I know it’s an issue with the capture.
    The first 30 minutes of footage captures fine with no glitches. Then, out of nowhere, the capture starts to break up and scene detection starts going crazy (it captures a new clip every second or two). I end up with hundreds of tiny little clips that are broken up from eachother. Even if the clips are strung together on the timeline, it looks and sounds choppy.
    *There is no break in the footage when it starts to go bad during capture. There are no pauses, pans, tilts, etc.
    Here’s what I’ve tried (nothing has worked):
    -Rebooting computer & camera
    -Minimizing hardware acceleration
    -Capturing to both internal and external harddrives (both have ample space and are fast enough)
    -Stopped and started capturing in various locations
    -Disabling device control (so I control playback options manually on the camera)
    One thing I’ve tried (but it hasn’t worked) is downconverting the footage using the camera and feeding it to Vegas as an SD signal ( I’m not even sure if this is possible). Every time the video signal ends up scrambled on the camera LCD monitor and nothing is captured in Vegas.
    Any suggestions? At the very least I at least need usable audio. Thanks in advance.
    Karl Soehnlein
    Reel Wave Media, LLC
    Steve Rhoden replied 17 years, 9 months ago 2 Members · 1 Reply
  • Steve Rhoden
    January 6, 2009 at 7:35 am
    Well you can try using another capture utility to see
    if things captures correctly.
    Most times i use WinDV to capture my DV footages and
    CapDVHS to capture my HD footages…..
    You don’t have to limit yourself to doing everything in Vegas
    if their is a glitch somewhere. So try CapDVHS or HDVSplit
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
