Activity › Forums › VEGAS Pro › Vegas 8 crashing in 64-bit Vista
  • Vegas 8 crashing in 64-bit Vista
    Posted by Jason Yip on June 2, 2009 at 9:00 pm
    So I just got a new i7 based computer and installed Vegas 8 Pro. Loaded up my latest project and started rendering. It gets off to a good start but then blue screen of death about 5 minutes into rendering. Called tech support and no help there. So now I’m wondering if it’s the computer hardware or software problem. Everything seems to run fine with less CPU intense functions. Or could this be an operating system bug? I am running Vista Home Premium 64-bit and Vegas 8c which is 32-bit. Can this be the cause? Any advice would be greatly appreciated. Would like to give it a chance before wrapping this thing up and sending it back. THANKS!
    Nigel O’neill replied 17 years, 3 months ago 3 Members · 2 Replies
  • Corey Whitley
    June 3, 2009 at 9:21 pm
    I think there is a 64 bit update on Sony Vegas website.
    Also I had some crashing issues on long render projects. Someone told me to change a preference that is automatically checked when packaged.
    Under general preferences, down at the bottom, un-check the “Enable no-recompress long-GOP rendering”.
    I also started to disconnect from the internet when rendering and make sure all of my open windows were on the same monitor if using a dual monitor setup. Anything to put less pressure on the cpu.
    Hope this helps.
    Corey Whitley
  • Nigel O’neill
    June 8, 2009 at 11:51 am
    Jason
    I don’t believe your problem lies in Vegas Pro 8.
    Without further information about the blue screen message, there could be multiple causes:
    – your system is overheating under load. You could test this by removing your case cover and blowing a fan on it. If your render works OK, note that this is only a temporary fix and you need to get a better cooling system.
    – you have a buggy driver. I had massive NVIDIA driver issues (BSOD with nvata.sys errors) which I resolved by rolling back the drivers (video and RAID) to Microsoft drivers. This assumes your motherboard has NVIDIA video/RAID.
    – you have faulty RAM or mismatched RAM to your motherboard. Check with the motherboard manufacturer.
    – you have a faulty HDD (it does happen, even for new systems – I had a faulty Raptor installed once)
    Hope this helps.
