Activity Forums VEGAS Pro Vegas 8 crashes with crossfades
  • Vegas 8 crashes with crossfades
    Posted by Cory Sea on June 24, 2008 at 1:02 pm
    Hello,
    I have a quad core Vista 64 bit computer. When I overlap two files on the same track to crossfade(either manually or automatically) in Vegas 8b, a number of bad things happen:
    1)the transition scrubs fine but the crossfade in real time blacks out the second file.
    2)I get an error message and the program locks up when I play the
    transition.
    In both cases the program crashes.
    I welcome any help.
    Many thanks,
    Cory Sea
    Jeremy Rasnic replied 18 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Rasnic
    June 26, 2008 at 9:18 pm
    Can you provide anymore details about what file types you are using, if any other transitions work and if it has ever worked in the past for you.
    j razz
