Vegas 8 Crashes constantly especially while rendering – Windows 7
Posted by Roger Bansemer on December 19, 2009 at 4:37 amI’ve recently installed Windows 7 32 bit on a fast new computer. Now Vegas crashes all the time and I can’t reneder any project at all without it crashing or in one instance it said it would take 22 hours to render a 15 minute video.
I read something about maybe having a bad or wrong codec. I’m not much on knowing about codecs. Can anyone in simple language tell me what I might do to fix this.
I’m working with the M2ts files (which I find annoying)
ThanksNorman Willis replied 16 years, 9 months ago 3 Members · 3 Replies -
Al Bergstein
December 19, 2009 at 5:52 amI’m under the impression that on Windows 7 you are ‘supposed’ to be running 64 bit Windows 7 to run Vegas Video 9.0c. (is 32 bit even officially supported on Windows 7?). If true, then that could be your problem, running into a bug in the software. Also, you didn’t mention what CPU and how much ram you have in this machine.
I’m running 64 bit VV 9.0.c on Win7, with a quad core and 6 GBs RAM and it renders whatever I throw at it, at least for 10 minutes at a time (I’ve not tried longer). I have not had it ‘crash’ yet for rendering, though video issues, outside of VV have caused a few blue screens of death. But not rendering. And I’m coming off AVCHD into lower res output. Also have rendered Sony Digital 8 stuff on it with no problems.
hope this helps.
Alf
Panasonic HMC-150 & Vegas Video -
Roger Bansemer
December 19, 2009 at 1:08 pmI took a group of M2ts files and put them on the time line without any editing and they render fine. Yet when I put my project on the timeline it crashes every time even when I stripped out everything inlcuding the audio track and just left a few clips.
I’m using windows 7 32 bit with Vegas 8 build 260.Do you have any ideas?
Here’s the info I got after the crash:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: vegas80.exe
Application Version: 8.0.0.260
Application Timestamp: 48c7daa4
Fault Module Name: vegas80.exe
Fault Module Version: 8.0.0.260
Fault Module Timestamp: 48c7daa4
Exception Code: c0000005
Exception Offset: 002c8325
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Then I loaded the veg file and elimated all but 3 clips and it still crashed (with this message)System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.ApplicationException: File already exists: B:test_MainConcept MPEG-2_DVD Architect NTSC Widescreen video stream.mpg
at EntryPoint.DoRender(String filePath, RenderItem renderItem, Timecode start, Timecode length)
at EntryPoint.DoBatchRender(ArrayList selectedTemplates, String basePath, RenderMode renderMode)
at EntryPoint.FromVegas(Vegas vegas)
— End of inner exception stack trace —
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Sony.Vegas.ScriptHost.ScriptManager.Run(Assembly asm, String className, String methodName)
at Sony.Vegas.ScriptHost.CodeDomScriptManager.Run()
at Sony.Vegas.ScriptHost.RunScript(Boolean fCompileOnly) -
Norman Willis
December 21, 2009 at 6:09 amHi Roger.
This is a noob grasp at straws, but I don’t know what else to offer.
Can you try either downloading a free trial of Cineform NeoScene to convert your m2ts files to .avi (at least as a troubleshooting technique)?
And/or can you try a trial download of VPro 9, if only to get you through this particular project?
Just some thoughts. I hope they help.
Norman Willis
http://www.nazareneisrael.org
