Activity Forums VEGAS Pro Vegas 7 Umcompressed Problems!
  • Vegas 7 Umcompressed Problems!
    Posted by Jason_ziggy on May 10, 2007 at 11:30 pm
    Hello!
    I want to render a project (NTSC DV) to AVI uncompressed in Vegas 7. It seems to render fine. But, Vegas splits the video into 6 different files instead of one (like it should!) I have a 300 gig hard drive…so I am not hurting for disk space.
    If I can’t get this fixed…what is the BEST POSSIBLE render option after uncompressed (for best quality)?
    Thank you!
    Jason
    Terje A. bergesen replied 19 years, 3 months ago 5 Members · 6 Replies
  • Mike Kujbida
    May 11, 2007 at 12:31 am
    I’ll bet that your drive is formatted as FAT-32 instead of NTFS.
    Change it and you’ll be fine.
    If this is your system drive, then I’d strongly recommend picking up a second drive (they’re cheap these days so get a 500 GB, either internal or external) and make sure it’s formatted as NTFS before you use it.
  • Gary Kleiner
    May 11, 2007 at 2:08 am
    [jason_ziggy] “what is the BEST POSSIBLE render option”
    Without knowing what kind of material you are working with and what your use will be, it’s not easy to answer that.
    It’s unlikely that rendering as uncompressed will serve any purpose beyond creating huge files for you.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Jason_ziggy
    May 11, 2007 at 6:33 pm
    I am already rendering to an external drive (300 g). Is it to late to reformat?
  • Jason_ziggy
    May 11, 2007 at 6:34 pm
    I don’t mind the big film…I will export it to Quicktime DVPro in FinalCut.
    What more information do you need to know?
  • Rob Mack
    May 12, 2007 at 8:44 pm
    It’s not too late to reformat if that’s the problem, but you have to move everything you wan to keep to some other drive first. Reformatting will erase the drive in the process.
    Rob Mack
  • Terje A. bergesen
    May 14, 2007 at 4:53 am
    You won’t need to re format, but you might want to keep a backup of your drive somewhere while you do this. Open up a command prompt window (popularly called DOS window, though there is no DOS in XP). Run the following command:
    convert /FS:NTFS :
    For example, if your drive is E:, then convert /fs:ntfs e:
    Terje A. Bergesen : https://terje.bergesen.info/
