Activity Forums VEGAS Pro Vegas 7 licence
  • Vegas 7 licence
    Posted by Craig Cooper on April 19, 2007 at 8:50 pm
    I work from home and from my studio. Will I be able to install Vegas 7 at both locations?
    I am interested in buying vegas 7 but can’t afford 2 packages.
    Mike Kujbida replied 19 years, 5 months ago 3 Members · 3 Replies
  • Edward Troxel
    April 19, 2007 at 9:24 pm
    Yes, you can legally install Vegas on two machines. You just cannot legally USE Vegas on both at the same time.
    Edward Troxel
    JETDV Scripts
  • Craig Cooper
    April 20, 2007 at 6:17 am
    Thanks for the quick reply.
    Does registration and licensing take place on the web? If so then the second authorisation might be denied. Is that correct?
  • Mike Kujbida
    April 20, 2007 at 10:26 am
    Not to worry. Here’s the official answer from Sony:
    BTW, I’ve done this numerous times without any hassles whatsoever.
    Question
    Can I run my Sony Media Software application on more than one PC?
    Answer
    Our licensing agreement permits you to install the software on as many machines as you own, as long as you are not running the programs at the same time. For instance, you can install the software on your home machine and on your laptop. You are not allowed to install the software on multiple machines if you are going to be using them simultaneously, such as in a home studio setting. If you are going to run the software concurrently on more than one machine, you would need to purchase a separate license for each computer.
    Note that when you install the software on a different computer you will need to complete the registration process again. Register the software as you did the first time to unlock the program on each machine. You can register online directly within the software, via the phone, or on our website through our online form.
