Activity Forums VEGAS Pro Vegas 64bit
  • Vegas 64bit
    Posted by Enrique Orozco on October 20, 2009 at 10:49 pm
    I-m upgrading to windows 7 64bit hoping to use Vegas 9pro 64 bit… is it true that almost no external plugins work with these version ….magic bullet, newblue, prodad…. can I open 32 bit projects with 64 bit version…. can I run both versions on the same machine….
    any help would be greatly apreciated…
    Enrique
    Enrique Orozco R.
    iDEA DigitalVideoStudio
    Dave Haynie replied 16 years, 10 months ago 4 Members · 5 Replies
  • John Rofrano
    October 21, 2009 at 1:57 pm
    Less true than before but still a lot of pliug-ins don’t support 64-bit yet. The VASST script plug-ins, Excalibur, iZotope, & NewBlueFX are a few that that do work, not sure about the others (I don’t think Magic Bullet does).
    Yes, but none of the 32-bit plug-ins will load.
    Absolutely. There is no other way to use Vegas unless you only stick to the small subset of codecs and FX that are 64-bit enabled. I, for one, cannot.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Enrique Orozco
    October 21, 2009 at 3:04 pm
    Thank you John… do I need to install Vegas 9pro 32bit with another OS (maybe XP)… or will it run in the same windows 7 environment with the 64 bit version ?
    … this is something odd… I’m no software expert but the new Adobe 64bit programs doesn´t have “2 versions” to care about.. and they have thousands of external plugins…. anyway I love Vegas.. just a thought..
    thanks again
    Enrique Orozco R.
  • John Rofrano
    October 21, 2009 at 4:31 pm
    Install it on the same Windows 7 64-bit environment. It will happily run in 32-bit mode. This is how I work everyday.
    Which Adobe 64-bit programs are you referring to?
    I have the latest Adobe Creative Suite 4 (CS4) and the only 64-bit program that ships with it is Photoshop CS4 64-bit and NONE of my Photoshop plug-ins work with it (just like Vegas) so I just use the 32-bit version instead. I’m curious what program you are referring to that has all of this 64-bit support?
    ~jr
  • Enrique Orozco
    October 21, 2009 at 5:37 pm
    …yes, John, youre absolutely right… my confusion with CS4 based on a 64bit white paper from Adobe…. premiere, after effects are optimized but only photoshop is native 64bit…. but as I said, I stay with vegas….
    thanks again…
    Enrique Orozco R.
  • Dave Haynie
    October 21, 2009 at 5:55 pm
    Adobe doesn’t have much in the way of actual 64-bit programs. But, for the CS4 edition, they are fully 64-bit buzzphrase compatible:
    “Gain up to 227% performance improvement when you use Adobe Premiere Pro CS4 on a 64-bit system with more memory.”
    “Adobe Premiere® Pro CS4 software is architected and optimized for 64 bit operating systems.”
    Most people would ASSUME that means this is a 64-bit application. It’s not. Apparently, they have just fixed some bugs working on 64-bit systems, and made the applications IMAGE_FILE_LARGE_ADDRESS_AWARE flagged.
    That’s not useless… an IMAGE_FILE_LARGE_ADDRESS_AWARE 32-bit application on a 64-bit system can get twice as much RAM as a default 32-bit application on a 32-bit system. Not that they’re bending over backwards to clarify this.
    -Dave
