Activity › Forums › VEGAS Pro › Vegas 6, transparent background using PNG and transistion, possible?
  • Vegas 6, transparent background using PNG and transistion, possible?
    Posted by Steve Battershell on January 25, 2008 at 2:54 am
    I’m editing a peice and it calls for some product shots to be onscreen. I put these in as 32bit PNG files to maintain a transparent background around the product shots. I’d like to use a transistion to fly these in and out of screen. As soon as the transistion starts, a black box shows up around the product where the transparency was. Is there anyway to fix this?
    Laszlo Kovacs replied 18 years, 8 months ago 4 Members · 5 Replies
  • Edward Troxel
    January 25, 2008 at 3:33 pm
    I just tried this and everything worked as I expected it to work. I didn’t get any black in the transparent areas. I tried a bunch of different transitions too.
    Edward Troxel
    JETDV Scripts
  • Jerry Norman
    January 25, 2008 at 3:58 pm
    Steve, I got the same results as Edward… unless I didn’t have any media on the track(s) below the png track. Then I do get the black square.
    As an experiment, try inserting white generated media in the track below your png and see if the black box goes away – it does for me.
    I do not know of a way to maintain the transparency using a transition. However, a possible workaround is to use track motion to fly in your png. Then, transparency is maintained.
  • Steve Battershell
    January 25, 2008 at 4:17 pm
    Thanks guys you’ve given me some ideas, I’ll try these. Yes I do have media below the PNG layer.
  • Edward Troxel
    January 25, 2008 at 4:29 pm
    I had a png with a transparent background on track 1 and another full screen png on track 2. Track 2 was never blocked (no extra black anywhere) except where it should be no matter what transition I used. I didn’t try them all but I tried several.
    Edward Troxel
    JETDV Scripts
  • Laszlo Kovacs
    January 25, 2008 at 4:49 pm
    some time ago I had similar problem with transitions that came with wax. No problem however with the builtin transitions.
    Regards
    K.L.
