Activity › Forums › VEGAS Pro › vegas 6 preview problem!
  • vegas 6 preview problem!
    Posted by Russell Miller on January 31, 2008 at 12:58 am
    Hello, The problem I have is probably very simple to fix, but for some reason it has definitly given me a hard time for the last couple of days. The problem is I can’t figure out how to have the video preview and the video fx window up at the same time. I have messed with the view menu, but no luck. Any help would be appreciated! It makes it very hard to work with color effects adjustments when you have to tab back and forth for preview to vid fx.
    Russell Miller replied 18 years, 8 months ago 2 Members · 2 Replies
  • Edward Troxel
    January 31, 2008 at 3:50 am
    Sounds like you have them docked together. Get to where you’re viewing the FX. In the upper left corner should be a series of dots going downward. Click on those dots and drag away from that area.
    Edward Troxel
    JETDV Scripts
  • Russell Miller
    January 31, 2008 at 4:22 am
    Problem solved! Thanks so much
