Activity Forums VEGAS Pro Vegas 22 portrait video only shows bottom half of video…
  • Vegas 22 portrait video only shows bottom half of video…
    Posted by Rob Xpyakyalo on January 28, 2025 at 1:17 am
    Yes version 22.0.0.239, latest to January ’24, when I start a new portrait video, and import any portrait video, in the trimmer and preview window, the video top half is black. Works fine if sent to a a second monitor or rendered… But.. it’s not working in the main UI on the single monitor. Always worked fine in vegas 21, so wondering if this is a bug or on my end? Can’t really be my end as the both versions are on my computer at the same time.
    Brie Clayton
    replied 1 year, 7 months ago
    3 Members · 4 Replies
  • Baskeh Dewitt
    January 28, 2025 at 1:28 am
    Hey Rob,
    This issue sounds like it could be related to your GPU.
    First, make sure your GPU drivers are up to date. You can find the latest drivers on your GPU manufactures website. Do make sure you download the correct driver for your GPU model. After you’ve updated the drivers (if there were any) give your PC a restart and see if the issue persists or not.
    Alternatively, you could try adjusting your GPU Acceleration settings in Vegas. Go to Options > Preferences > Video. Under GPU acceleration of video processing, switch to Off (for troubleshooting). Or switch to your dedicated GPU (if it was previously set to the wrong GPU or “off”).
    Let me know how it goes!
  • Rob Xpyakyalo
    January 28, 2025 at 1:36 am
    Okay thank you. I turned of GPU acceleration and it immediately worked. I will now upgrade my drivers as yes, it’s a new Windows install and I have not updated them. Thank you for the fast response!
  • Baskeh Dewitt
    January 28, 2025 at 1:16 pm
    Great to hear, I’m glad I was able to help! ^^
  • Brie Clayton
    January 28, 2025 at 2:37 pm
    Thank you for solving this, Baskeh!
