Vegas 14 really really slow render times
Posted by John Parks on October 20, 2016 at 10:32 pmHey Creative Cow experts!
Thank you in advance for looking at this with me.
So today I upgraded from Vegas 13 to 14, and right off the bat my render times have become really, really slow. Machine is a PC laptop with 16GB RAM and Intel I7, at least 400GB free on hard drive. 90-second clip would take no time in 13; now 14 is showing 46 minutes for that same 90-second clip.
Render settings and project properties on screenshots.
Any thoughts? THANK YOU!
John W. Parks IV, D.M.A.
Professor of Percussion
The Florida State UniversityJohn Parks replied 9 years, 11 months ago 4 Members · 13 Replies -
Mark Barton
October 20, 2016 at 11:48 pmAre you sure you asked it to render only the region you selected that is 90s? I would have expected long times with VP13 with 32bit color. Perhaps double check the Video Preview RAM setting on both 13 and 14 under Options/Preferences/Video. Sometimes this setting can impact render times.
John Parks
October 21, 2016 at 12:04 amHey Mark,
Thanks for your message! Yes, just looped region (box is checked). In fact, even with increasing RAM for preview from 200 to 4000 doesn’t do anything.
Here’s something weird though–there are no options for GPU acceleration of video processing–only “no.” Could that be the culprit? And would that have changed in this version (since 13 worked perfectly with the same computer)?
The render has yet to get past 2% no matter how I tweak the settings. Surely there’s a box somewhere that I’m overlooking?
Seriously frustrated. JP
The Florida State Universityhttp://www.johnparkspercussion.com
Mark Barton
October 21, 2016 at 12:26 amI was thinking your laptop did not have a supported GPU, so I did not mention that. Did you see it offer a GPU card under the VP13 Preferences? If you do, then go into VP14 and hold down the shift key when you select Preferences from the option menu. At this point you should see a tab called Internal. In the search field type in “GPU” and you should see an option of Allow GPU Rendering = FALSE. You can try setting this to TRUE and then go back into Preferences to see if the option is present. You may have to restart VP14 for it to take effect. There is a reason they disabled it, but perhaps you will have good luck with it and the short clips you are rendering. I found that GPU rendering for me worked ok for short clips, but longer projects would result in stalls/crashes in VP13. Anyway, you can always set the option back to FALSE if it does not help.
John Parks
October 21, 2016 at 12:39 amHey Mark,
I tried the GPU enable option under internal, switched to “TRUE,” and then nothing still shows up under GPU acceleration even with a restart. The video tutorials I’ve watched tonight all have the graphics card show up there, and mine still has “no” as the only option.
I’m guessing that 14 just doesn’t like my graphics card (Intel HD Graphics 3000)…probably no one likes that card. But it worked just fine in 13 and in various MS versions I had years before.
Would you say that’s probably it? I’m guessing my next step would be to call Magix tomorrow and talk them through the situation. If I have to get another graphics card, are there any that you all would recommend?
JP
John Parks
October 21, 2016 at 2:04 amI’ve uninstalled and reinstalled, same issue. In fact, the render of that 90-second clip hangs at 2% and the projected time jumps by 20-second increments towards infinity. I stopped the last one at 1 hour, with only 2% showing.
UGH! JP
Mark Barton
October 21, 2016 at 4:44 amYou usually do not have an option to switch out a video card on a laptop, you are normally stuck with what is integrated on the system board since there are no expansion slots like there are on desktops. I did not think that GPU would work with VP13, so you say it showed up in the options there in the Video tab? I got better stability in VP14 when I removed some of the plugins that were not being used. I found my application extensions and started renaming the directories to hide them from VP14. The reason why was they did not work with VP14, but according to Process Explorer, vegas140.exe was maintaining a file handle to them. So now I just have Boris Red 5.5, BCC 9, Vegasaur 3, and NewBlue Titler Pro 4. I pulled out my VASST FASST apps, Production Assistant 2, ScatterShot 3D, and Timeline Tools since they do not work with VP14 yet.
John Parks
October 21, 2016 at 3:59 pmNo, it didn’t show up in 13 either, which makes me think that 14 shouldn’t need GPU acceleration.
I spent about 40 minutes combing through the Magix site, which was seriously unhelpful. Called customer service 10 times over an hour and finally got someone who would not patch me over to tech support.
Then finally sent two emails to support@magix.net, and both were returned as undeliverable.
Then found a spot to fill in my issue and sent that off…hopefully someone will get back to me.
Has no one else in 14 had the same problems? JP
Ole Kristiansen
October 21, 2016 at 4:21 pmTry google: OpenCL support for Intel HD graphics cards !
Ole
John Parks
October 21, 2016 at 6:00 pmThanks Ole! I did that and I’m not sure anything changed…
George Dean
October 21, 2016 at 10:51 pmHi John,
John Parks @ “In fact, even with increasing RAM for preview from 200 to 4000 doesn’t do anything.“. If you haven’t already, I would set the Dynamic RAM back to 200. In the test I made, going above 2000 started to slow down the render times. You might not see a huge difference in render time if set at 4000, but if you don’t need it that high for Dynamic RAM preview, it will only hurt render times setting it really high. It supposed does better than v13, but it is not perfect and still has limitations.
Have you tried to start a new project with a fresh source media, maybe a minute or two long and test the render times? There may be something in your project, or in the source media of your project which the render is tripping on. A fresh project and source should avoid this. Also, you may want to reset Vegas and delete the cache, just to make sure there isn’t something nasty stuck in there before making the fresh project test.
I’m not familiar with your laptop, does it have Intel Quick Sync Video? And, if so, is there an option for that in the Sony AVC render template? This might decrease render times.
Another option, which doesn’t shine any enlightenment to address you question, is to use the Vegas2Handbrake script, which will DebugMode FrameServe your project out and render in Handbrake. Handbrake usually will give you better quality, a faster render and smaller file size……just a suggestion. I use this process for anything that goes to YouTube or PC for playback.
Best Regards……George
