Activity Forums VEGAS Pro Vegas 14 — Audio in editor sounds fine, but it sounds clipped when rendered to MP4
  • Vegas 14 — Audio in editor sounds fine, but it sounds clipped when rendered to MP4
    Posted by Matt Staroscik on July 1, 2018 at 10:18 pm
    I have a really simple project based on video imported from a Sony AVCHD camera. The audio was captured by the camera’s own mic and recorded in 5.1. I have no idea what the original codec is, but the camera stores MTS files.
    In the project preview, it sounds fine.
    When exported as MP4, it sizzles and sounds like it’s clipping.
    Is there anything I can do in Vegas to fix this? While I have SoundForge, the built-in feature that lets you adjust a Vegas audio track in SoundForge won’t work with this video clip, it says it cannot read audio data. The camera is about 8 years old though so that may be a factor.
    Francois Pénzes replied 8 years, 2 months ago 2 Members · 3 Replies
  • Francois Pénzes
    July 2, 2018 at 2:23 am
    Hi Matt
    If the audio sounds good in preview, then it was recorded fine. I would start by looking at your audio settings in Preferences, Audio Device. Also take a look at the Advance tab. I am assuming here that you have a dedicated audio card.
    This would help us help you. https://sourceforge.net/projects/mediainfo/ It will tell us a lot about your original file.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 14, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Matt Staroscik
    July 2, 2018 at 3:34 am
    First, thank you kindly for your reply!
    Well, the good news is that the issue seems to be some kind of playback problem. When I played the file back on another computer entirely, it sounded fine. So, there is something about the app that I used to check my rendered MP4 that is not working as expected, meaning this isn’t a Vegas problem.
    More good news, when I checked my audio device settings I noticed that Vegas was not using the GPU to render. I assumed it would be on by default, and never looked… I flipped that on, and rendering is about 10x faster now.
    My main problem with Vegas is that I use it about once every year or two, so every time I use it, I am starting from scratch! ????
    Though, there is still one related issue I would like to resolve. When I was trying to solve this issue in Vegas, I wanted to look at the audio in SoundForge–there is a Vegas menu selection just for that. Unfortunately, according to the error message I got, SoundForge 10 cannot read AC-3 files, it seems.
    Is this expected, or is it because my ancient camera produces some kind of non-compliant AC-3 file? Does Vegas 15 come with a newer version of SoundForge that understands 5.1 AC-3 files?
    Below is the complete MediaInfo output for my source file. (Technically it isn’t a raw source file–Vegas saw my camera and imported the clip, stitching together 2 MTS files from the camera filesystem.)
    Thanks again!
    General
    Complete name : C:\Users\staro\Documents\Imported Media\00001_20180701_073702.mts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 3.90 GiB
    Duration : 58 min 5 s
    Overall bit rate mode : Variable
    Overall bit rate : 9 612 kb/s
    Maximum Overall bit rate : 18.0 Mb/s
    Recorded date : 2018-07-01 07:07:35-07:00
    Writing application : Sony HDR-CX700V
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4
    Format settings : CABAC / 2 Ref Frames
    Format settings, CABAC : Yes
    Format settings, RefFrames : 2 frames
    Format settings, GOP : M=2, N=15
    Codec ID : 27
    Bit rate mode : Variable
    Bit rate : 8 773 kb/s
    Maximum bit rate : 16.0 Mb/s
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 (30000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.188
    Stream size : 3.56 GiB (91%)
    IrisFNumber : 3.400000
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 129
    Bit rate mode : Constant
    Bit rate : 448 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -67 ms
    Stream size : 186 MiB (5%)
    Service kind : Complete Main
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 58 min 4 s
  • Francois Pénzes
    July 2, 2018 at 11:54 am
    Hi Matt
    AC-3 is a delivery format not an editing format. You would have to convert that AC-3 file to an editable format of your liking, say, a Uncompressed PCM .WAV for example.
    Cheers !
