Activity › Forums › VEGAS Pro › Vegas 13: I cannot achieve the desired result with keyframes
  • Vegas 13: I cannot achieve the desired result with keyframes
    Posted by John Rodriguez on January 2, 2026 at 6:35 pm
    Im using the Pan/Crop thing on Video Event, using the Position keyframes to move the position of the camera. I want a smooth movement that starts from a stationary camera, then slowly goes down while moving to the left, then it continues scrolling down in a linear speed.
    https://imgur.com/WiMJfGN
    As you can see here, I cannot get the movement properly. Any ideas?
    I just think this is not possible to do unless I could draw envelopes (like you can do with the “Animate” keyframes on effects or in the timeline with volume and pan).
    https://i.imgur.com/D5hBQtZ.png
    I would need to be able to draw the X movement and the Y movement differently. But with a keyframe, everything is contained within the keyframe, so it will never be smooth enough. The “Smoothness” interpolation thing I don’t think it’s going to do it. So I don’t know what to do.
    https://i.imgur.com/X8tYKGC.png
    Like I said I would need to animate the X movement to smoothly move to the left, then stop moving to the left decelerating smoothly, while the Y moves down starting from a stationary position, then mantains a reasonable speed scrolling down to see the thumbnails (the red squares, this is a placeholder)
    If anyone knows how to do this please let me know. Thanks
    View post on imgur.com
    Silviu Negoita
    replied 2 months, 1 week ago
    2 Members · 1 Reply
  • Silviu Negoita
    July 21, 2026 at 3:28 pm
    Hi!
    You’re right, Event pan/crop in VEGAS doesn’t let you edit separate motion curves for the X and y axes.
    A couple workarounds you can try
    1. Use Track Motion instead of Pan/Crop, it ussually gives smoother camera movement.
    2.Add more keyframes.
    3.Try different keyframe interpolation modes, experiment wigth the Smooth, Fast,Slow or Linear.
    Since the version you are using is a pretty old one there aren’t many solutions.
