Ricardo Farah
November 25, 2014 at 9:56 pmI don’t understood what You meant, but i’m supposing You told me that the problem is the firmware version. I don’t make sense cause AVC reads and convert the file.
John Rofrano
November 25, 2014 at 10:03 pmYou said that after you updated the firmware that it started writing the files differently. It may have something to do with that. Can you go back to the old firmware?
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Ricardo Farah
November 25, 2014 at 10:27 pmI think it’s possible but not so easy. Anyway I will not use standalone anymore. I just need to render those vídeos….it took almost 1 hour to make it with comentaries…..and it’s a scary gameplay wich can’t be as good as the the first time We playied. I’m trying right now to convert with AVC and see if it gives me an “OK” video.
Ricardo Farah
November 26, 2014 at 11:30 amSo, I found out that only the preview generated have a poor light/quality. When I recoded the file, the movie wasn’t darker, it was almost PERFECT like the original.
So the mistery of vegas and happauge stand alone will last for some more time. Problem not solved but it’s not relevant any more.
Thanks by Your time trying to help John.
Hope never need stand alone mode again. Thank You, have a lot to work to demand to my processor now. 🙂
John Rofrano
November 26, 2014 at 12:48 pm -
Ricardo Farah
March 31, 2015 at 3:03 pmI was passing to post another topic and remembered to update this one.
The issue was with my capture card. Aparently something with the Thumb drive i was using formated to fat32 or something with the USB Microfone ON on the options. Those were corrected via Happauge support.
But nowadays when I format my computer i just install k-litemega codec pack and Quick Time and everything works flawslessly.
