Activity › Forums › VEGAS Pro › Vegas 12 stops rendering at 20%, how to fix this
  • Vegas 12 stops rendering at 20%, how to fix this
    Posted by T.s. Chauhan on May 25, 2017 at 4:14 pm
    Hi
    Vegas 12 stops rendering at 20%, how to fix this, error is indicated as:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 12.0 (Build 770) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCR90.dll
    Fault Address: 0x000000005CC0E2ED Fault Offset: 0x000000000001E2ED
    My system specifications are : GTX 780 Ti
    Thanks for the help in advance
    Peter Gregg replied 9 years, 3 months ago 3 Members · 19 Replies
  • 19 Replies
  • Graham Bernard
    May 25, 2017 at 9:02 pm
    If you have GPU acceleration ON, try turning it OFF.
    * Grazie
  • T.s. Chauhan
    May 26, 2017 at 12:47 am
    Hi, thanks, I have already put it off, no use at all.
  • Graham Bernard
    May 26, 2017 at 5:26 am
    Have you render this setup before?
    OK, open the PC and see if it very dusty inside. Fans, fan portals, grids and mesh and any “blankets” of accumulated hairs+dust. Rendering is a big use of PC hardware, this equates with temperature rise. Keep an eye on your Core PC Temp with this: https://www.alcpu.com/CoreTemp/
    Which reminds me . . . .
    * Grazie
  • T.s. Chauhan
    May 26, 2017 at 6:51 am
    Graham Bernard Hi,Thanks for your kind reply. Yes I have been rendering this set up for quite long now, this is the first time that such an error has been come up. Vegas Pop up, which clearly describes the fault , needs to be dealt with. But I dont know how. Can you read this and understand this. How to proceed further in this direction please?
    It reads as follows:
    Problem Description
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 12.0\vegas120.exe
    Process Version: Version 12.0 (Build 770) 64-bit
    Process Description: Vegas Pro
    I will be thankful for your kind help.
  • Graham Bernard
    May 26, 2017 at 7:33 am
    Have you knowingly accepted a M$ Update? Check your update history and see what may have been installed with special attention to .NET Framework.
    * Grazie
  • T.s. Chauhan
    May 26, 2017 at 8:34 am
    No, I haven’t accepted anything, and honestly speaking I dont know, in my 8.1 version of windows, updates are automatically done, I guess. And how to check them exactly? Let me try. I will just check and see if I could understand them or not.
    Thanks.
  • Graham Bernard
    May 26, 2017 at 8:55 am
    Look, the bottom line here is that you say that you’ve done all this render process before and just now it won’t. You got to investigate what may have changed recently.
    * Grazie
  • T.s. Chauhan
    May 26, 2017 at 9:05 am
    Yes, Thanks, Just looking up for the recent changes if any.
    Regards.
  • Graham Bernard
    May 26, 2017 at 9:27 am
    Have you opened the PC to look and see if there is anything blocking the ventilation?
    * Grazie
  • T.s. Chauhan
    May 27, 2017 at 11:22 pm
    Hi, thanks.
    No, nothing is blocking the ventilation.
    Still searching the fix, I have searched some updates for 8.1 version of OS (I am using), but those are optional ones.
    No further progress yet.
