Activity › Forums › VEGAS Pro › Vegas 12 stops rendering at 20%, how to fix this
  • Graham Bernard
    May 28, 2017 at 4:20 am
    Look at your Update History in the updater manager. This will show you what updates were downloaded and installed. Looking at what “is” available, your optional comment, is not the same as what “has” been downloaded and installed. And again, has any of the .NET Framework updates been installed. If so note the date it happened on.
    * Grazie
  • T.s. Chauhan
    May 28, 2017 at 3:53 pm
    Hi there,
    Thanks for your kind reply. You are very correct, I have seen .NET location, the vgas while crashing at 20% indicate the message like this: C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCR90.dll
    and I have seen this file in the C drive, I don’t know if it is corrupted or what, and what needs to be done with this file, or it needs to be re-installed or what? Also I found no new updates recently installed.
    How to deal with this further.
    Thanks & Regards Mr Graham Bernard.
  • Graham Bernard
    May 29, 2017 at 5:28 am
    Can you see if the .NET Framework is being suggested as an update? Are you capable of determining just which.Net Framework you are currently working with?
    Another thought: Have you recently installed new software? I say this because I recently installed some graphics software and it flagged up the need for a newer version of .NET Framework and went ahead and installed it! I discovered this because I interrogated the M$ Updater and saw Updater had indeed installed a new version of .NET.
    * Grazie
  • T.s. Chauhan
    May 29, 2017 at 7:55 am
    I can’t determine which .NET framework I am currently working. Its problem.
  • Graham Bernard
    May 29, 2017 at 9:29 am
    [T.s. Chauhan] “I can’t determine which .NET framework I am currently working”
    Yes, that is a problem. Sorry, can’t help any further.
    * Grazie
  • T.s. Chauhan
    May 29, 2017 at 10:29 am
    Ok, fine, still thankful to you. Can you suggest any other Forum where I can get the solution.
    Thanks.
  • Graham Bernard
    May 29, 2017 at 12:12 pm
    [T.s. Chauhan] “Can you suggest any other Forum where I can get the solution.”
    You’re already signed up with and asked the same question on the MAGIX VP Forum. Has that helped?
    * Grazie
  • T.s. Chauhan
    May 29, 2017 at 2:31 pm
    Thanks for your reply,
    Unfortunately they have not yet replied and given any look into the matter, everybody seem to be less interested in Vegas crashing issue. Its very irritating topic though, but Vegas is otherwise a great warrior , sometimes it starts giving its users great shocks as well.
    Thanks.
  • Peter Gregg
    June 4, 2017 at 3:55 pm
    I was rendering a 28 minute video last night. It stopped rendering at 58 percent. I saw this thread last time it happened and I found my computers video card settings had changed so the fan speed was back to default.
    I have the RX480 card, and it has software to allow me to control the fan speed on the video card. I had previously had these freezes and I upped the fan speed from the default of 780rpm to over 3000rpm. It worked then. On last night’s render, it froze again. I checked the Global Wattman (the name of he software that came with the RX480) and it indeed had gone back to default fan speed. I set it back to manual and upped the fan speed to over 3000 rpm again, rebooted the computer and started my render again. It went thru with flying colors.
    I don’t know why it reverted back to default settings, and I was really annoyed when I found the render had stopped this morning again. But making the video card run cooler allowed the render to go back to normal. I don’t know if this will help you, but I figured I would share it. I also try and do a “spring cleaning” every year and clean out my computer’s insides and I haven’t done that yet this year. Will have to get on that too ☺
    Peter
Page 2 of 2
