Activity › Forums › VEGAS Pro › Vegas 11. No sound in DVD
  • Vegas 11. No sound in DVD
    Posted by John Gregoriades on December 4, 2011 at 8:36 pm
    Hello once again,
    I’ve used a Vegas 11, and would like to render so that the result can be burned into a normal-playable DVD disk using either Nero (7) or Windows DVD Maker (W7 Pro).
    I tried rendering as MPEG2, and using either program the DVD ends up as a “mute” (no audio) DVD.
    I could use some help as to what render-settings to use. (for ordinary NTSC 4:3 best quality.)….there are so many choices…!
    Many thanks,
    John
    John Rofrano replied 14 years, 10 months ago 3 Members · 6 Replies
  • John Rofrano
    December 4, 2011 at 9:01 pm
    If you rendered using one of the DVD Architect templates but you’re not using DVD Architect that’s your problem. Programs like Nero are expecting the Audi to be included in the MPEG2 file. Use one of the standard NTSC DVD templates which should include audio. You can always press the Custom button and check the Audio tab to make sure the audio is included in any template.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    December 4, 2011 at 11:28 pm
    I think its because you are rendering out using one of the
    DVD Architect Templates, Which wont include any audio…
    Try the DVD NTSC Template.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • John Gregoriades
    December 5, 2011 at 4:23 am
    Many thanks, gentlemen.
    You pointed out exactly what I was doing wrong.
    (I did try the NTSC-DVD as well as the NTSC-MPEG-2 settings and they both worked OK, in making a DVD disk using Windows DVD maker. I could not tell the difference. Is there any?)
    John23GR
  • Steve Rhoden
    December 5, 2011 at 1:14 pm
    None that you can see…lol
    Glad we could help.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
  • John Gregoriades
    December 5, 2011 at 2:39 pm
    Hoho, love a man with a sense of humor!
    Happy Holidays!
    john
    John23GR
  • John Rofrano
    December 5, 2011 at 9:05 pm
    Yea, the only difference is that one doesn’t contain an audio stream because you really want to render the audio as a separate AC3 stream for maximum quality because MPEG2 audio is not part of the NTSC DVD spec. While some burning software allows you to use it, there is no guarantee that it will work on all players.
    ~jr
