Activity Forums VEGAS Pro Vegas 11 crashing when rendering to MP4
  • Vegas 11 crashing when rendering to MP4
    Posted by Bob Mark on July 25, 2012 at 4:14 pm
    I’m using Vegas Pro 11 build 683 64 bit. I am having trouble rendering to MP4. It either crashes the program or says an unexpected error occurred. What is the best codec for MP4 with Vegas? Thanks.
    Bob
    Bob Mark replied 14 years, 1 month ago 2 Members · 10 Replies
  • 10 Replies
  • Jeff Schroeder
    July 25, 2012 at 7:25 pm
    Hey Bob,
    Which codec are you using? MainConcept or Sony?
    Are you trying to use a template that produces an .m2ts file?
    Ever installed a codec pack (sorry, I had to ask.)
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Bob Mark
    July 26, 2012 at 7:37 pm
    I have tried many different ones. Some work and some don’t. I didn’t get the crashing until recently. WMP would not play some of the files, so it must have been a codec thing. I will install the latest Codec pack for Win 7. What works best for you with MP4? Thanks.
    Bob
  • Jeff Schroeder
    July 26, 2012 at 9:21 pm
    No, no, no, don’t install a codec pack. The always make trouble for Vegas and any other video editing platform.
    I use Sony’s AVC codec. I’ve not had any problems with it.
    Give more details about the crash… What was the cause? Who was the culprit? (it should be in the error message or the windows event logs.)
    Jeff
  • Bob Mark
    July 31, 2012 at 4:03 pm
    I get crashes on rendering. Here’s what it said:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 11.0 (Build 683) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Windowssystem32amdocl64.dll
    Fault Address: 0x000007FEEE4AE52C
    Fault Offset: 0x000000000006E52C
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 11.0vegas110.exe
    Process Version: Version 11.0 (Build 683) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2012-04-27 (Fri Apr 27) 20:43:00
    Bob
  • Jeff Schroeder
    July 31, 2012 at 4:07 pm
    The file listere under Fault Module: C:Windows/system32/amdocl64.dll
    Belongs to your video card driver for open CL runtime.
    It is made by AMD, not Sony.
    Jeff
  • Bob Mark
    July 31, 2012 at 6:32 pm
    I have GPU assist turned off. I can render with Vegas 8 but not 11.
    My laptop is HP and they say the graphics card driver is up to date,
    but AMD has a newer version (they won’t release it to me, they say contact HP).
    Bob
  • Jeff Schroeder
    August 1, 2012 at 12:16 am
    Try going back a version.
  • Bob Mark
    August 1, 2012 at 1:46 pm
    I only have V. 8 to go back to. I can try another build of V. 11.
    Thanks.
    Bob
  • Jeff Schroeder
    August 1, 2012 at 2:55 pm
    I meant back a version on your video card driver.
  • Bob Mark
    August 1, 2012 at 6:25 pm
    Jeff, I think you are right that the AMD card is the problem. I disabled it and used the on board Intel gfx and I could render MP4 using the Sony codecs. I could not get the Main Concept template to work. Thanks.
    Bob
