Activity Forums VEGAS Pro [Vegas 11] Changing Aspect Ratio to Wide creates horizontal lines. (With Screenshots)
  • [Vegas 11] Changing Aspect Ratio to Wide creates horizontal lines. (With Screenshots)
    Posted by Kirmmela on February 9, 2012 at 10:01 am
    I got a HD footage that I needed to edit, but the aspect ratio was square, so when I changed to widescreen I’ve got the annoying black vertical lines at the sides as you see in the screenshot 1. So when I changeed the aspect ratio to 16:9 they disappear, but then I get the vertical lines on the video itself all over the footage (screenshot 2 / click on the screen to see more detailed version). Any idea how how to solve this problem guys?
    Thanks, Katrine.
    Mike Kujbida replied 14 years, 7 months ago 2 Members · 3 Replies
  • Mike Kujbida
    February 9, 2012 at 3:34 pm
    Is this the only video in the project?
    If it is, setting your project properties to exactly match your source video will eliminate the black bars without you having to do anything.
    The lines you’re seeing are interlace lines and my guess is that they’ll disappear if you set your Preview window to Best/Full.
  • Kirmmela
    February 9, 2012 at 9:02 pm
    Thank you! It worked, changed the project properties to the same parameters as the video. <3
  • Mike Kujbida
    February 10, 2012 at 12:05 am
    Glad to hear that was the solution.
    That fix is one that is commonly overlooked yet can make a big difference in all kinds of things.
