Activity › Forums › VEGAS Pro › Vegas 10e crash – “vegas100k.dll”
  • Vegas 10e crash – “vegas100k.dll”
    Posted by Neal Barlow on July 29, 2013 at 2:08 am
    I’m scratching my head on an error that just came up. I’ve been work on a short film for the last year and I took a few weeks off on the edit, and when I try to open the timeline I get an error. I’m working in Vegas 10, and here is what I get:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0e (Build 737)
    Problem: Unmanaged Exception (0xc0000094)
    Fault Module: C:Program Files (x86)SonyVegas Pro 10.0vegas100k.dll
    Fault Address: 0x1022476A
    Fault Offset: 0x0022476A
    Fault Process Details
    Process Path: C:Program Files (x86)SonyVegas Pro 10.0vegas100.exe
    Process Version: Version 10.0e (Build 737)
    Process Description: Vegas Pro
    Process Image Date: 2011-06-29 (Wed Jun 29) 19:23:38
    I’ve tried uninstalling/reinstalling – Other computers with 10 and same error. It loads to 31% and then crashes and states this error. I have tried with both the 32bit and 64bit versions.
    Can you help a brother out?
    Neal Barlow
    To The Skies – Productions
    The Cult Classic Returns in ZOMBIES DURING THIRD PERIOD: AGAIN
    Neal Barlow replied 13 years, 2 months ago 3 Members · 9 Replies
  • 9 Replies
  • Tyson Onaga
    July 29, 2013 at 3:01 am
    If you know where the media is, you could:
    a. Copy your .veg
    b. Move media location (eg, change/create a new folder)
    c. Open .veg
    You should get the Media not found dialog.
    d. Add one; ignore the rest.
    e. Save the .veg
    Keep repeating (d) and (e) and see if you run into a problem source media file.
  • Neal Barlow
    July 29, 2013 at 3:45 am
    Have you had this problem before?
    Neal Barlow
  • Stephen Mann
    July 29, 2013 at 4:33 am
    “Unmanaged Exception” is almost always a driver issue. Have you changed any hardware or drivers since it last worked?
    But, you said you tried it on another PC and got the same error? Could you be missing a third-party plugin?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Tyson Onaga
    July 29, 2013 at 4:56 pm
    No. I’d check what Stephen mentioned; ie, changes on your system. If there aren’t any, then I’d start looking at individual media items you have used in your problem .veg.
  • Neal Barlow
    July 29, 2013 at 8:32 pm
    I updated my video driver. I can try undoing that, but that wouldn’t explain why it gave me the same error on another computer. I did also add a second monitor.
    Neal Barlow
  • Stephen Mann
    July 30, 2013 at 3:15 am
    Post your veg file.
    Steve Mann
    http://www.mmdv.com
  • Neal Barlow
    July 30, 2013 at 4:45 am
    Here it is. It loads until 31% and then locks up.
    6341_finalaltorder.veg.zip
    Neal Barlow
  • Stephen Mann
    July 30, 2013 at 1:10 pm
    I tried your veg file with random media from my projects and the veg file loads fine.
    try splitting the project into temporary shorter projects and see if you can localize the error better.
    Steve Mann
    http://www.mmdv.com
  • Neal Barlow
    July 30, 2013 at 5:41 pm
    Thanks Steve. It seems that part of the problem is the Hard drive dumped some data and I lost half the footage. It was looking for it on the network and hard drive, but wouldn’t give me a prompt until I moved the .veg file. Total bummer.
    I appreciate all whole trouble shot for me. Great community here!
    Neal Barlow
