veg file not saving mp3 as the music
Posted by John Williams on October 17, 2019 at 11:40 amI want to use mp3 as the music rather than the sound on the camera. Nikon D3200. I start the video,save the veg. But when i open to edit further the veg file does not include the music?
John Williams replied 6 years, 11 months ago 2 Members · 7 Replies -
Francois Pénzes
October 17, 2019 at 8:23 pmHi John
First off, what version of Vegas Pro are you using ? Was the audio recorded separately from the video ?
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
John Williams
October 18, 2019 at 12:38 amVegas pro 13. The mp3 are from a free music site that allows use if they are given credit in the video
Francois Pénzes
October 18, 2019 at 3:20 amHi John
With Vegas, render the .MP3 audio track to .WAV
Do you get the same problem ?
Cheers !
John Williams
October 18, 2019 at 11:19 amI think you misunderstood. I was trying to save the mp3 to a veg project file with video
Francois Pénzes
October 18, 2019 at 11:51 amHi John
Please, humour me.
Tell me me if I’m way off base here. You’re working on an edit that has separate video and audio files. When you want to save the project (as a .VEG) it won’t let you. Correct ?
If so, and this is for the process of elimination, render your .MP3 track by itself as a .WAV
Replace your .MP3 file in your edit with the .WAV file.
Can you save your project as a .VEG now ?
Tip: if you move your original .MP3 file after saving your project to .VEG (thus saving all your edit points and effects) upon re-opening and getting the File Missing message, point to the new .WAV file and replace.
Reason is that sometimes, some files, randomly and without any appearance of logic will create problems of all kinds. Even from one comp to another you may get different responses from the same software. There has been numerous documented instances on this forum and elsewhere regarding .MP3 problems.
I know it’s not always possible but if one can, try to get an un-compressed file right off the bat. MP3 files are really compressed.
Cheers !
PC Win 10 Pro 64-bit 16gb AMD Rysen® 9-3900x 12 Core 4.60GHz
John Williams
October 18, 2019 at 12:52 pm“Tell me me if I’m way off base here. You’re working on an edit that has separate video and audio files. When you want to save the project (as a .VEG) it won’t let you. Correct ?” Yes that is it. It saves it but only the video is there when i open the veg again and it says “do you want to search for the mp3.” I can search for the mp3 but it is the original one not edited to fit the video
I will try your suggestion re wav and get back to you. Thanks
John Williams
October 18, 2019 at 1:15 pmHi Francois
Yes it works with a wav file. I will just get the wav version of the file.Thanks for your help.
